[postgis-tickets] [PostGIS] #5012: winnie ticket rounding regress on tickets and buffer_params
trac at osgeo.org
Wed Oct 20 15:10:34 PDT 2021
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: buildbots | Version: master
Keywords: |
PostgreSQL 11.12, compiled by Visual C++ build 1914, 64-bit
Postgis 3.2.0dev - (3.2.0alpha1-50-gb02b7bf7b) - 2021-10-16 19:15:57
scripts 3.2.0dev 3.2.0alpha1-50-gb02b7bf7b
raster scripts 3.2.0dev 3.2.0alpha1-50-gb02b7bf7b
GEOS: 3.10.0beta3-CAPI-1.16.0
PROJ: 7.1.1
SFCGAL: 1.4.0
GDAL: GDAL 3.2.3, released 2021/04/27
./regress/core/regress_buffer_params .. failed (diff expected obtained:
/projects/postgis/tmp/3.2.0dev_pg11_geos3.10_gdal3.2.3w64/test_46_diff)
--- ./regress/core/regress_buffer_params_expected 2021-10-16
14:57:43.594235200 -0400
+++ /projects/postgis/tmp/3.2.0dev_pg11_geos3.10_gdal3.2.3w64/test_46_out
2021-10-16 16:00:24.439547700 -0400
@@ -1,4 +1,4 @@
-point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,1.6155e-15 -1,-0.7071
-0.7071,-1 -3.2311e-15,-0.7071 0.7071,-4.6246e-15 1,0.7071 0.7071,1 0))
+point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,6.123e-17 -1,-0.7071
-0.7071,-1 -1.2246e-16,-0.7071 0.7071,-1.8369e-16 1,0.7071 0.7071,1 0))
line quadsegs=2|POLYGON((10 2,11.414 1.414,12 0,11.414 -1.414,10 -2,0
-2,-1.414 -1.414,-2 2.449e-16,-1.414 1.414,0 2,10 2))
line quadsegs=2 endcap=flat|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
line quadsegs=2 endcap=butt|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
/tmp/3.2.0dev_pg11_geos3.10_gdal3.2.3w64/test_81_diff)
--- ./regress/core/tickets_expected 2021-10-16 14:57:48.640534100
-0400
+++ /projects/postgis/tmp/3.2.0dev_pg11_geos3.10_gdal3.2.3w64/test_81_out
2021-10-16 16:06:54.024173000 -0400
@@ -91,7 +91,7 @@
#835.11|MULTILINESTRING EMPTY
#835.12|MULTIPOLYGON EMPTY
#650|MULTIPOINT(0 0,1 1,2 2)
-#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.99999999999987,30
40))
+#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.99999999999999,30
40))
#677.deprecated|1121395
#677|1121395
#680|01d107000000000000000024c000000000000049400000000000000040
I just noticed debbie was set to run against 3.9 so if it was a 3.10 issue
she wasn't testing. Checking on her. That said not sure why winnie isn't
at rc2. Will retest on newly released 3.10 to see if still and issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5012>
