[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0alpha1-51-gad775f152
Wed Oct 20 18:07:01 PDT 2021
the project "PostGIS".
       via  ad775f152e043c3173d1943c5d45ccb9562d3e3e (commit)
      from  b02b7bf7b64337665e2e824d15e71f2d2c02734e (commit)
revisions in full, below.
commit ad775f152e043c3173d1943c5d45ccb9562d3e3e
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Oct 20 21:05:56 2021 -0400
    Fix regress caused by rounding differences
    between GEOS 3.10 and older GEOS
    References #5012 for PostGIS 3.2.0
diff --git a/regress/core/regress_buffer_params.sql b/regress/core/regress_buffer_params.sql
index 2e05a7f08..63a546c51 100644
--- a/regress/core/regress_buffer_params.sql
+++ b/regress/core/regress_buffer_params.sql
@@ -5,7 +5,7 @@
 -- Ouput is snapped to grid to account for small floating numbers
 -- differences between architectures
-SELECT 'point quadsegs=2', ST_AsText(st_buffer('POINT(0 0)', 1, 'quad_segs=2'), 4);
+SELECT 'point quadsegs=2', ST_AsText( ST_SnapToGrid(st_buffer('POINT(0 0)', 1, 'quad_segs=2'), 0.0001), 4);
 SELECT 'line quadsegs=2', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2'), 3);
 SELECT 'line quadsegs=2 endcap=flat', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=flat'), 5);
 SELECT 'line quadsegs=2 endcap=butt', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=butt'), 5);
diff --git a/regress/core/regress_buffer_params_expected b/regress/core/regress_buffer_params_expected
index 6bd9d4f0e..28847444e 100644
--- a/regress/core/regress_buffer_params_expected
+++ b/regress/core/regress_buffer_params_expected
@@ -1,4 +1,4 @@
-point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,1.6155e-15 -1,-0.7071 -0.7071,-1 -3.2311e-15,-0.7071 0.7071,-4.6246e-15 1,0.7071 0.7071,1 0))
+point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,0 -1,-0.7071 -0.7071,-1 0,-0.7071 0.7071,0 1,0.7071 0.7071,1 0))
 line quadsegs=2|POLYGON((10 2,11.414 1.414,12 0,11.414 -1.414,10 -2,0 -2,-1.414 -1.414,-2 2.449e-16,-1.414 1.414,0 2,10 2))
 line quadsegs=2 endcap=flat|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
 line quadsegs=2 endcap=butt|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 12a5d1111..03f080ee7 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -303,7 +303,7 @@ SELECT '#650', ST_AsText(ST_Collect(ARRAY[ST_MakePoint(0,0), ST_MakePoint(1,1),
 --SELECT '#662', ST_MakePolygon(ST_AddPoint(ST_AddPoint(ST_MakeLine(ST_SetSRID(ST_MakePointM(i+m,j,m),4326),ST_SetSRID(ST_MakePointM(j+m,i-m,m),4326)),ST_SetSRID(ST_MakePointM(i,j,m),4326)),ST_SetSRID(ST_MakePointM(i+m,j,m),4326))) As the_geom FROM generate_series(-10,50,20) As i CROSS JOIN generate_series(50,70, 20) As j CROSS JOIN generate_series(1,2) As m ORDER BY i, j, m, i*j*m LIMIT 1;
 -- #667 --
-SELECT '#667', ST_AsEWKT(ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j))) As the_geom FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, j, i*j LIMIT 1;
+SELECT '#667', ST_AsEWKT( ST_LineToCurve(ST_Buffer(ST_SetSRID(ST_Point(i,j),4326), j)), 10 ) As the_geom FROM generate_series(-10,50,10) As i CROSS JOIN generate_series(40,70, 20) As j ORDER BY i, j, i*j LIMIT 1;
 -- #677 --
 SELECT '#677.deprecated',round(ST_DistanceSpheroid(ST_GeomFromEWKT('MULTIPOLYGON(((-10 40,-10 55,-10 70,5 40,-10 40)))'), ST_GeomFromEWKT('MULTIPOINT(20 40,20 55,20 70,35 40,35 55,35 70,50 40,50 55,50 70)'), 'SPHEROID["GRS_1980",6378137,298.257222101]')) As result;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 8af08eb4d..5317bce63 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -91,7 +91,7 @@ NOTICE:  Too few points in geometry component at or near point 0 0
 #835.11|MULTILINESTRING EMPTY
 #835.12|MULTIPOLYGON EMPTY
 #650|MULTIPOINT(0 0,1 1,2 2)
-#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 39.99999999999987,30 40))
+#667|SRID=4326;CURVEPOLYGON(CIRCULARSTRING(30 40,-50 40,30 40))
 #677.deprecated|1121395
 #677|1121395
 #680|01d107000000000000000024c000000000000049400000000000000040
Summary of changes:
 regress/core/regress_buffer_params.sql      | 2 +-
 regress/core/regress_buffer_params_expected | 2 +-
 regress/core/tickets.sql                    | 2 +-
 regress/core/tickets_expected               | 2 +-
 4 files changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
