[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. 1ae544696cd7f06d71e6d55b222f846d09645f89
git at osgeo.org
git at osgeo.org
Sat Oct 23 18:15:10 PDT 2021
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
via 1ae544696cd7f06d71e6d55b222f846d09645f89 (commit)
from 8236205f53843d0ef5519a17535af1def8b89d1a (commit)
revisions in full, below.
commit 1ae544696cd7f06d71e6d55b222f846d09645f89
Author: Regina Obe <lr at pcorp.us>
Date: Sat Oct 23 21:15:05 2021 -0400
Update to include ntpd time service
diff --git a/freebsd/bessie32_setup.txt b/freebsd/bessie32_setup.txt
index 29c6706..3e714bb 100644
--- a/freebsd/bessie32_setup.txt
+++ b/freebsd/bessie32_setup.txt
@@ -155,4 +155,9 @@ pkg install postgresql11-contrib #needed to get citext
#note said this may be needed for compiling -Wl,-rpath=/usr/local/lib/gcc9
sudo gmake install
sudo gmake installcheck PGUSER=postgres
-sudo cpan TAP::Parser::SourceHandler::pgTAP
\ No newline at end of file
+sudo cpan TAP::Parser::SourceHandler::pgTAP
+#Make suretime service is running and starts on bootup otherwise looses time
+# https://forums.freebsd.org/threads/the-system-clock-is-falling-behind.61450/
+service ntpd enable
+service ntpd start
diff --git a/freebsd/bessie_setup.txt b/freebsd/bessie_setup.txt
index 5c4dae9..3269019 100644
--- a/freebsd/bessie_setup.txt
+++ b/freebsd/bessie_setup.txt
@@ -186,3 +186,8 @@ pkg info –all
pkg remove postgresql12-server postgresql12-contrib postgresql12-client gdal
pkg install postgresql12-server postgresql12-contrib postgresql12-client gdal
/usr/local/etc/rc.d/postgresql initdb
+service ntpd start
Summary of changes:
freebsd/bessie32_setup.txt | 7 ++++++-
freebsd/bessie_setup.txt | 5 +++++
2 files changed, 11 insertions(+), 1 deletion(-)
hooks/post-receive
