[postgis-tickets] [PostGIS] #4985: 32-bit crashers on cluster regress
trac at osgeo.org
Wed Sep 1 05:51:25 PDT 2021
Reporter: robe | Owner: komzpa
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by robe):
Here is the bt full after [7a7736ae/git]
#0 0xee5c2f1c in ST_ClusterKMeans (fcinfo=0xffb570fc) at
lwgeom_window.c:214
i = <optimized out>
k = 41982649
geoms = <optimized out>
N = 3
isnull = true
isout = false
max_radius = 0
r = <optimized out>
argdatum = 0
winobj = 0x280b0b8
context = 0x2786f48
curpos = <optimized out>
rowcount = <optimized out>
#1 0x00261ff4 in eval_windowfunction (perfuncstate=0x280ad70,
result=0x280ad40, isnull=0x280ad58, winstate=<optimized out>,
winstate=<optimized out>) at nodeWindowAgg.c:1055
fcinfodata = {fcinfo = {flinfo = 0x280ad7c, context = 0x280b0b8,
resultinfo = 0x0, fncollation = 0, isnull = false, nargs = 3, args =
0xffb57110},
fcinfo_data =
"|\255\200\002\270\260\200\002\000\000\000\000\000\000\000\000\000+\003\000\200\002\000\000\001\206p\000\000\000\000\000\001\000\000\000\351\375\000\000\001\330v\002\330\026\177\002X\263M\000\210\354\201\002\260\376\177\367\324W\215\367\220q\265\377`,\200\002e,\200\002\000\000\000\000\300k\"\000`,\200\002h,\200\002e,\200\002\070w\"\000pɀ\002\324W\215\367\bX\215\367\377\017\000\000\bX\215\367\324W\215\367XR\215\367\000\000\000\000\b\200\000\000\224\315\177\367\000\200\000\000\000\000\000\000\020\000\000\000h,\200\002e,\200\002\020d~\002\fDM\000x\313y\002\020\000\000\000\274\206p\000\001\000\000\000\000\000\000\000\270\314y\002\003\000\000\000\001\000\000\000X"...}
fcinfo = 0xffb570f4
oldContext = 0x276caf0
#2 0x00264ce0 in ExecWindowAgg (pstate=0x276d0f0) at nodeWindowAgg.c:2197
perfuncstate = <optimized out>
winstate = 0x276d0f0
econtext = 0x280ad58
i = 0
numfuncs = 1
__func__ = "ExecWindowAgg"
#3 0x00253224 in ExecProcNode (node=0x276d0f0) at
../../../src/include/executor/executor.h:242
Full output attached
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4985#comment:4>
