[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-493-gb4387f1
Thu Sep 2 13:38:30 PDT 2021
the project "PostGIS".
       via  b4387f1810a25185e0b250e794a4ab40ba78f7bc (commit)
       via  0a2eb22d77fa3f94a00585da43df96338aa45a01 (commit)
       via  c5fadb0a1bf3191d8e9f7742f17bdadcd11a1ffe (commit)
      from  0140c071c14bfa33c08df5c0133451a3cce37565 (commit)
revisions in full, below.
commit b4387f1810a25185e0b250e794a4ab40ba78f7bc
Merge: 0140c07 0a2eb22
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Sep 2 23:37:59 2021 +0300
    Add tip about how to get debug level logs
    Closes https://github.com/postgis/postgis/pull/637
commit 0a2eb22d77fa3f94a00585da43df96338aa45a01
Merge: 6809237 c5fadb0
Author: Björn Harrtell <bjornharrtell at users.noreply.github.com>
Date:   Thu Sep 2 14:48:46 2021 +0000
    Merge c5fadb0a1bf3191d8e9f7742f17bdadcd11a1ffe into 6809237109671ebba3c249772fe884e67e4006f6
commit c5fadb0a1bf3191d8e9f7742f17bdadcd11a1ffe
Date:   Thu Sep 2 16:48:34 2021 +0200
diff --git a/README.postgis b/README.postgis
index 24fdc9c..a1ea9e0 100644
--- a/README.postgis
+++ b/README.postgis
@@ -182,7 +182,7 @@ in a cloned postgis repository to later get core dump log output:
 > sudo bash ./ci/travis/logbt --setup
 Then you can run the following to get a docker container up and running with the
-correct requirements already in place and the postgis repository (at /postgis)
+correct requirements already in place and the postgis repository (at `/postgis`)
 mounted into it:
 > docker run -it --mount type=bind,source=/postgis,target=/src/postgis \
@@ -196,6 +196,18 @@ postgis tests:
 You can make customized versions of `run_usan_gcc.sh` to run only specific tests
 and skip redundant steps.
+If you need to get debug level logging in the PostgreSQL logs you can get it by
+manipulating configuration in the container. Add these lines after the `./configure`
+step:
+```sh
+sed -i 's/POSTGIS_DEBUG_LEVEL [0-9]$/POSTGIS_DEBUG_LEVEL 4/' postgis_config.h
+sed -i 's/#log_min_messages = warning/log_min_messages = debug5/' \
+/var/lib/postgresql/postgresql.conf
+Note that PostgreSQL logs are directed to `/tmp/logfile` in fx. `run_usan_gcc.sh`.
 INSTALLATION
Summary of changes:
 README.postgis | 14 +++++++++++++-
 1 file changed, 13 insertions(+), 1 deletion(-)
hooks/post-receive
