[postgis-tickets] [PostGIS] #4987: Reorganize spatial_ref_sys
trac at osgeo.org
Fri Sep 3 07:25:41 PDT 2021
Reporter: strk | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: postgis | Version: master
Keywords: |
The current strategy of mixing custom and system records in the same
spatial_ref_sys table is a bit complex and prone to errors on upgrade,
whereas users changing a system record would see those records changed on
upgrade.
This ticket is to find a cleaner solution.
My proposal is to turn spatial_ref_sys into a view and provide
spatial_ref_sys_postgis containing the official entries and a
spatial_ref_sys_user to contain custom/overridden entries.
The view would pick records from spatial_ref_sys_user in preference to
those in spatial_ref_sys_postgis.
I've given this solution a try and with a non-materialized view the
performance hit is that a _user table with ~100 overrides makes a query
for a single SRID 2.5x slower than directly fetching that record from a
table (but it's still around 2ms on my laptop).
Test of my implementation is in
https://gitlab.com/postgis/postgis/-/merge_requests/57
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4987>
