[postgis-tickets] [SCM] PostGIS branch stable-3.0 updated. 3.0.3-40-g0599561
git at osgeo.org
git at osgeo.org
Fri Sep 3 19:03:08 PDT 2021
the project "PostGIS".
The branch, stable-3.0 has been updated
via 05995619622b81850dd28e63d45c6b3d2f84ed0e (commit)
from eddbbc7c80272255e19e01b59ccdb196b5cfc1ec (commit)
revisions in full, below.
commit 05995619622b81850dd28e63d45c6b3d2f84ed0e
Author: Regina Obe <lr at pcorp.us>
Date: Fri Sep 3 22:03:02 2021 -0400
More doco changes
diff --git a/README.postgis b/README.postgis
index 78832c2..a1a96f1 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.0.3
-:Date: 2020-11-19
+:Version: 3.0.4
+:Date: 2021-09-04
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
@@ -33,7 +33,7 @@ Directory structure::
REQUIREMENTS
-PostGIS is compatible with PostgreSQL 9.5 and above.
+PostGIS is compatible with PostgreSQL 9.5 - 13.
You *must* have the full PostgreSQL - including server headers - installed for
this to work.
diff --git a/doc/installation.xml b/doc/installation.xml
index 7f84c7d..5a22748 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -113,7 +113,7 @@ psql -d yourdatabase -f sfcgal_comments.sql
<itemizedlist>
<listitem>
<para>
- PostgreSQL &min_postgres_version; or higher. A complete installation
+ PostgreSQL &min_postgres_version; - 13. A complete installation
of PostgreSQL (including server headers) is required. PostgreSQL
is available from
<ulink url="http://www.postgresql.org">
@@ -158,7 +158,7 @@ psql -d yourdatabase -f sfcgal_comments.sql
<listitem>
<para>
- GEOS geometry library, version 3.6 or greater, but GEOS 3.7+ is recommended to take full advantage of all the new functions and features. GEOS is available for download from
+ GEOS geometry library, version 3.6 or greater, but GEOS 3.8+ is recommended to take full advantage of all the new functions and features. GEOS is available for download from
<ulink url="http://trac.osgeo.org/geos/">
</ulink>.
@@ -2484,33 +2484,33 @@ ALTER EXTENSION postgis_topology UPDATE TO "&last_release_version;next";</progra
<programlisting>ALTER TABLE spatial_ref_sys ADD CONSTRAINT spatial_ref_sys_srid_check check (srid > 0 AND srid < 999000 );</programlisting>
<programlisting>ALTER TABLE spatial_ref_sys ADD PRIMARY KEY(srid));</programlisting>
If you are upgrading an old database containing french <ulink url="https://en.wikipedia.org/wiki/Institut_g%C3%A9ographique_national">
IGN
- </ulink> cartography, you will have probably SRIDs out
+ </ulink> cartography, you will have probably SRIDs out
of range and you will see, when importing your database, issues like this :
<programlisting> WARNING: SRID 310642222 converted to 999175 (in reserved zone)</programlisting>
- In this case, you can try following steps : first throw
- out completely the IGN from the sql which is resulting
+ In this case, you can try following steps : first throw
+ out completely the IGN from the sql which is resulting
from postgis_restore.pl. So, after having run :
<programlisting>perl utils/postgis_restore.pl "/somepath/olddb.backup" > olddb.sql</programlisting>
run this command :
<programlisting>grep -v IGNF olddb.sql > olddb-without-IGN.sql</programlisting>
- Create then your newdb, activate the required Postgis extensions,
+ Create then your newdb, activate the required Postgis extensions,
and insert properly the french system IGN with :
<ulink url="https://raw.githubusercontent.com/Remi-C/IGN_spatial_ref_for_PostGIS/master/Put_IGN_SRS_into_Postgis.sql">
this script
</ulink>
After these operations, import your data :
<programlisting>psql -h localhost -p 5432 -U postgres -d newdb -f olddb-without-IGN.sql 2> errors.txt</programlisting>
</para>
Summary of changes:
README.postgis | 6 +++---
doc/installation.xml | 30 +++++++++++++++---------------
2 files changed, 18 insertions(+), 18 deletions(-)
hooks/post-receive
