[postgis-tickets] [PostGIS] #4912: Postgres 11+ crashes with segmentation fault 11 when using SET STORAGE EXTERNAL on a `geographic` column
    trac at osgeo.org
    Fri Sep  3 20:05:24 PDT 2021
  Reporter:  progm    |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:  PostGIS 3.1.5
 Component:  postgis  |    Version:  3.1.x
Resolution:           |   Keywords:
Changes (by robe):
 * milestone:  PostGIS 3.1.4 => PostGIS 3.1.5
Comment:
 @pramsey did you try with the PostgreSQL geometry types?  I would assume
 that is a closer proxy to PostGIS.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4912#comment:6>
