[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.3-29-gff338b8
git at osgeo.org
git at osgeo.org
Fri Sep 3 21:00:42 PDT 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
via ff338b8fd6968edee2f5fa721a8d85cf539a402c (commit)
via ff1be8a6a33d43b4e9f8a5e8b8a1a2d2ec23f1bd (commit)
via cb8b6b81ae1ba60c0818fa45e8d4706df493464b (commit)
from 1a86e863aa799b34fb862ea96c9b177f914a53a0 (commit)
revisions in full, below.
commit ff338b8fd6968edee2f5fa721a8d85cf539a402c
Author: Regina Obe <lr at pcorp.us>
Date: Sat Sep 4 00:00:15 2021 -0400
Prepping for PostGIS 3.1.4 release
diff --git a/NEWS b/NEWS
index 061b79a..32c9f4e 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
-PostGIS 3.1.4dev
-2021/xx/xx
+PostGIS 3.1.4
+2021/09/04
* Bug Fixes
- #4782, Have postgis_restore.pl use backup postgis schema by
@@ -18,6 +18,8 @@ PostGIS 3.1.4dev
- #4958, TIGER2020 fix faces and add Tabblock20 (Regina Obe)
- #4959, Drop Colorado state files also drops national county tables (Regina Obe)
- #4916, #4770, #4724, #4916, Crashes in aggregate functions (Paul Ramsey)
+ - #4982, Problem when calling the buffer function from MobilityDB
+ (Esteban Zimanyi, MobilityDB)
PostGIS 3.1.3
diff --git a/README.postgis b/README.postgis
index 1369452..bb9515d 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.1.3
-:Date: 2021-07-02
+:Version: 3.1.4
+:Date: 2021-09-04
:Website: https://postgis.net
This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 4109242..007e591 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
POSTGIS_MAJOR_VERSION=3
POSTGIS_MINOR_VERSION=1
-POSTGIS_MICRO_VERSION=4dev
+POSTGIS_MICRO_VERSION=4
# Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
# when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 95ae28f..3230849 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,32 @@
<appendix id="release_notes">
<title>Appendix</title>
<subtitle>Release Notes</subtitle>
+ <sect1>
+ <title>Release 3.1.4</title>
+ <simplesect>
+ <title>Bug Fixes</title>
+ <para>Release date: 2021/09/04</para>
+ <para>#4782, Have postgis_restore.pl use backup postgis schema by
+ default (Sandro Santilli)</para>
+ <para>#4854, Fix type of TopoGeometry receiving different-type
+ TopoGeometry components (Sandro Santilli)</para>
+ <para>#4918, Fix rare crash in st_minpossiblevalue (Paul Ramsey)</para>
+ <para>#4941, Fix loose mbr in topology.face on update (Sandro Santilli)</para>
+ <para>#4949, Swapped coordinates for N/E planar systems (Paul Ramsey)</para>
+ <para>#GI617, Fix typo in setting of INVMINDIST (Charles Karney)</para>
+ <para>#4326, Fix CircularPolygon area calculation (Paul Ramsey)</para>
+ <para>#4917, Fix crasher with '-' regclass (Paul Ramsey)</para>
+ <para>#4919, Rare crash in selectivity calculation (Paul Ramsey)</para>
+ <para>#4926, Preserve SRID on unions of empty geometry (Paul Ramsey)</para>
+ <para>#4910, Allow repeated points in GML input poslists (Paul Ramsey)</para>
+ <para>#4958, TIGER2020 fix faces and add Tabblock20 (Regina Obe)</para>
+ <para>#4959, Drop Colorado state files also drops national county tables (Regina Obe)</para>
+ <para>#4916, #4770, #4724, #4916, Crashes in aggregate functions (Paul Ramsey)</para>
+ <para>#4982, Problem when calling the buffer function from MobilityDB
+ (Esteban Zimanyi, MobilityDB)</para>
+ </simplesect>
+ </sect1>
<sect1>
<title>Release 3.1.3</title>
<para>Release date: 2021/07/02</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 728237b..537796b 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -58,6 +58,7 @@ UPGRADEABLE_VERSIONS = \
3.0.1 \
3.0.2 \
3.0.3 \
+ 3.0.4 \
3.1.0 \
3.1.1 \
3.1.2 \
commit ff1be8a6a33d43b4e9f8a5e8b8a1a2d2ec23f1bd
Date: Fri Sep 3 23:33:12 2021 -0400
Handle null arg. Patch from Esteban Zimanyi, MobilityDB. References #4982 for PostGIS 3.1.4
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 2a7eb8c..b44bfb2 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -1044,8 +1044,7 @@ Datum buffer(PG_FUNCTION_ARGS)
else
- params_text = palloc(VARHDRSZ);
- SET_VARSIZE(params_text, 0);
+ params_text = cstring_to_text("");
/* Empty.Buffer() == Empty[polygon] */
commit cb8b6b81ae1ba60c0818fa45e8d4706df493464b
Date: Fri Sep 3 22:53:27 2021 -0400
Update ST_Azimuth to include more defs suggested by Francois Bonzon. References #4880 for PostGIS 3.1.4
diff --git a/doc/reference_measure.xml b/doc/reference_measure.xml
index 4bc966e..ff3c093 100644
--- a/doc/reference_measure.xml
+++ b/doc/reference_measure.xml
@@ -140,7 +140,8 @@ from somegeogtable;</programlisting>
<title>Description</title>
<para>Returns the azimuth in radians of the segment defined by the given
- point geometries, or NULL if the two points are coincident. The azimuth is angle is referenced from north, and is positive clockwise: North = 0; East = π/2; South = π; West = 3π/2.</para>
+ point geometries, or NULL if the two points are coincident. The azimuth is angle is referenced from north, and is positive clockwise: North = 0; Northeast = π/4; East = π/2; Southeast = 3π/4;
+ South = π; Southwest 5π/4; West = 3π/2; Northwest = 7π/4. </para>
<para>For the geography type, the forward azimuth is solved as part of the inverse geodesic problem.</para>
<para>The azimuth is mathematical concept defined as the angle between a reference plane and a point, with angular units in radians.
Units can be converted to degrees using a built-in PostgreSQL function degrees(), as shown in the example.</para>
Summary of changes:
NEWS | 6 ++++--
README.postgis | 4 ++--
Version.config | 2 +-
doc/reference_measure.xml | 3 ++-
doc/release_notes.xml | 26 ++++++++++++++++++++++++++
extensions/upgradeable_versions.mk | 1 +
postgis/lwgeom_geos.c | 3 +--
7 files changed, 37 insertions(+), 8 deletions(-)
hooks/post-receive
