[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-505-gd77e8b0
Thu Sep 9 22:53:59 PDT 2021
the project "PostGIS".
       via  d77e8b01b6d485d8e2564c96b438ec31790a3f02 (commit)
      from  6f9f76b7395f5c27c69c2136c53608e44ba0d38f (commit)
revisions in full, below.
commit d77e8b01b6d485d8e2564c96b438ec31790a3f02
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu Sep 9 22:53:38 2021 -0700
    Improve doc for bounding box functions
diff --git a/doc/reference_bbox.xml b/doc/reference_bbox.xml
index f086342..0bb09c7 100644
--- a/doc/reference_bbox.xml
+++ b/doc/reference_bbox.xml
@@ -256,30 +256,32 @@ BOX(-124.659652709961 24.6830825805664,-67.7798080444336 49.0012092590332)
 		<title>Description</title>
 		<para>This function returns a bounding box expanded from the bounding box of the input,
-			either by specifying a single distance with which the box should be expanded in all
-			directions, or by specifying an expansion distance for each direction.
+			either by specifying a single distance with which the box should be expanded on both
+			axes, or by specifying an expansion distance for each axis.
-			Uses double-precision. Can be very useful for distance queries, or to add a bounding box
+			Uses double-precision. Can be used for distance queries, or to add a bounding box
 			filter to a query to take advantage of a spatial index.</para>
-		<para>In addition to the geometry version of ST_Expand, which is the most commonly used, variants
-			are provided that accept and produce internal BOX2D and BOX3D data types.
+		<para>In addition to the version of ST_Expand accepting and returning a geometry, variants
+			are provided that accept and return
+            <xref linkend="box2d_type" /> and <xref linkend="box3d_type" /> data types.
 		</para>
-		<para>ST_Expand is similar in concept to <xref linkend="ST_Buffer" />,
-			except while buffer expands the geometry in all directions,
+		<para>Distances are in the units of the spatial reference system of the input.</para>
+		<para>ST_Expand is similar to <xref linkend="ST_Buffer" />,
+			except while buffering expands a geometry in all directions,
 			ST_Expand expands the bounding box along each axis.</para>
-		<para>Units are in the units of the spatial reference system in use denoted by the SRID.</para>
 		<note>
 		  <para>Pre version 1.3, ST_Expand was used in conjunction with <xref linkend="ST_Distance" /> to do indexable distance queries.  For example,
 			<code>geom && ST_Expand('POINT(10 20)', 10) AND ST_Distance(geom, 'POINT(10 20)') < 10</code>.
-			This has been replaced by the easier <xref linkend="ST_DWithin" /> construct.</para>
+			This has been replaced by the simpler and more efficient <xref linkend="ST_DWithin" /> function.</para>
 		</note>
-		<note>
-			<para>Availability: 1.5.0 behavior changed to output double precision instead of float4 coordinates.</para>
-			<para>Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
-			<para>Enhanced: 2.3.0 support was added to expand a box by different amounts in different dimensions.</para>
-		</note>
+        <para>Availability: 1.5.0 behavior changed to output double precision instead of float4 coordinates.</para>
+        <para>Enhanced: 2.0.0 support for Polyhedral surfaces, Triangles and TIN was introduced.</para>
+        <para>Enhanced: 2.3.0 support was added to expand a box by different amounts in different dimensions.</para>
 		<para>&P_support;</para>
 		<para>&T_support;</para>
@@ -314,7 +316,7 @@ SELECT ST_Expand(CAST('BOX3D(778783 2951741 1,794875 2970042.61545891 10)' As bo
 	  <refsection>
 		<title>See Also</title>
-		<para><xref linkend="ST_AsEWKT" />, <xref linkend="ST_Buffer" />, <xref linkend="ST_DWithin" />, <xref linkend="ST_GeomFromEWKT" />, <xref linkend="ST_GeomFromText" />, <xref linkend="ST_SRID" /></para>
+		<para><xref linkend="ST_Buffer" />, <xref linkend="ST_DWithin" />, <xref linkend="ST_SRID" /></para>
 	  </refsection>
 	</refentry>
@@ -336,22 +338,24 @@ SELECT ST_Expand(CAST('BOX3D(778783 2951741 1,794875 2970042.61545891 10)' As bo
 	  <refsection>
-		<para>ST_Extent returns a bounding box that encloses a set of geometries. The ST_Extent function is an "aggregate" function in the
+		<para>ST_Extent returns a <xref linkend="box2d_type" /> bounding box that encloses a set of geometries.
+            The ST_Extent function is an "aggregate" function in the
 			terminology of SQL. That means that it operates on lists
 			of data, in the same way the SUM() and AVG() functions do.</para>
-		<para>Since it returns a bounding box, the spatial Units are in the units of the spatial reference system in use denoted by the SRID</para>
-		<para>ST_Extent is similar in concept to Oracle Spatial/Locator's SDO_AGGR_MBR</para>
-		<note>
-		  <para>Since ST_Extent returns a bounding box, the SRID meta-data is lost.  Use ST_SetSRID to force it back into
-			a geometry with SRID meta data.  The coordinates are in the units of the spatial ref of the original geometries.</para>
-		</note>
+		<para>The bounding box coordinates are in the spatial reference system of the input geometries.</para>
+		<para>ST_Extent is similar in concept to Oracle Spatial/Locator's SDO_AGGR_MBR.</para>
 		<note>
-		  <para>ST_Extent will return boxes with only an x and y component even with (x,y,z) coordinate geometries.  To maintain x,y,z use ST_3DExtent instead.</para>
+		  <para>The returned <code>box3d</code> value does not include a SRID.
+            Use <xref linkend="ST_SetSRID" /> to convert it into a geometry with SRID metadata.
+            The SRID is the same as the input geometries.</para>
 		</note>
 		<note>
-		  <para>Availability: 1.4.0</para>
+		  <para>ST_Extent returns boxes with only x and y ordinates even with 3D geometries.
+          To provide x,y,z use <xref linkend="ST_3DExtent" /> instead.</para>
 		</note>
@@ -395,7 +399,7 @@ SELECT ST_SetSRID(ST_Extent(geom),2249) as bextent FROM sometable;
 	  <refsection>
-		<para><xref linkend="geometry_overlaps" />, <xref linkend="ST_AsEWKT" />, <xref linkend="ST_3DExtent" />, <xref linkend="ST_SetSRID" />, <xref linkend="ST_SRID" /></para>
+		<para><xref linkend="ST_3DExtent" />, <xref linkend="ST_SetSRID" /></para>
 	  </refsection>
 	</refentry>
@@ -417,14 +421,15 @@ SELECT ST_SetSRID(ST_Extent(geom),2249) as bextent FROM sometable;
 	  <refsection>
-		<para>ST_3DExtent returns a box3d (includes Z coordinate) bounding box that encloses a set of geometries. The ST_3DExtent function is an "aggregate" function in the
+		<para>ST_3DExtent returns a <xref linkend="box3d_type" /> (includes Z coordinate) bounding box that encloses a set of geometries. The ST_3DExtent function is an "aggregate" function in the
 		<note>
-		  <para>Since ST_3DExtent returns a bounding box, the SRID meta-data is lost.  Use ST_SetSRID to force it back into
 		</note>
@@ -462,7 +467,7 @@ FROM (SELECT ST_Translate(ST_Force_3DZ(ST_LineToCurve(ST_Buffer(ST_Point(x,y),1)
 	  <refsection>
-		<para><xref linkend="ST_Extent" />, <xref linkend="ST_Force_3DZ" /></para>
+		<para><xref linkend="ST_Extent" />, <xref linkend="ST_Force_3DZ" />, <xref linkend="ST_SetSRID" /></para>
 	  </refsection>
 	</refentry>
Summary of changes:
 doc/reference_bbox.xml | 65 +++++++++++++++++++++++++++-----------------------
 1 file changed, 35 insertions(+), 30 deletions(-)
hooks/post-receive
