[postgis-tickets] [PostGIS] #4405: Index over ST_Transform(constant, SRID) breaks pg_upgrade
trac at osgeo.org
Fri Sep 10 04:29:13 PDT 2021
Reporter: Algunenano | Owner: Algunenano
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS Fund Me
Component: build/upgrade/install | Version: master
Resolution: wontfix | Keywords:
Comment (by Algunenano):
> A reorganization of spatial_ref_sys might be an occasion to look at
this, see #4987
In this case, that reorganization would not fix the issue. As robe said,
the problem is that the table is created, then the indexes, then the data
is added.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4405#comment:13>
