[postgis-tickets] [PostGIS] #4990: getfacecontainingpoint fails on i386
PostGIS trac at osgeo.org
Sat Sep 11 00:55:56 PDT 2021
 Reporter:  Bas Couwenberg  |      Owner:  pramsey
     Type:  defect          |     Status:  new
 Priority:  medium          |  Milestone:  PostGIS 3.2.0
Component:  postgis         |    Version:  master
 Keywords:                  |
 The Debian package build for 3.2.0~alpha1 failed on i386 due to a test
 failure:
  ./topology/test/regress/getfacecontainingpoint .. failed (diff expected
 obtained: /tmp/pgis_reg/test_167_diff)
 --- ./topology/test/regress/getfacecontainingpoint_expected     2021-09-11
 03:34:25.000000000 +0000
 +++ /tmp/pgis_reg/test_167_out  2021-09-11 07:38:02.046054220 +0000
 @@ -21,21 +21,4 @@
  ERROR:  Two or more faces found
 -t1|1
 -t2|1
 -t3|9
 -t4|2
 -t5|2
 -t6|0
 -t7|11
 -t8|4
 -t9|1
 -t10|10
 -t11|10
 -t12|10
 -t13|10
 -t14|1
 -t15|12
 -t16|15
 -t17|16
 -t18|19
 +ERROR:  Closest point is first point of closest segment, unexpectedly
 [https://buildd.debian.org/status/fetch.php?pkg=postgis&arch=i386&ver=3.2.0~alpha1%2Bdfsg-1~exp1&stamp=1631345972&file=log
 Full buildlog]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4990>
