[postgis-tickets] [PostGIS] #4994: shp2pgsql is sometimes missing the INSERT statements
trac at osgeo.org
Wed Sep 15 12:58:24 PDT 2021
Reporter: myon | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.5
Component: postgis | Version: 2.5.x
Keywords: |
I've been chasing regression tests failures seen in 3.2 on Debian
unstable:
https://pgdgbuild.dus.dg-i.net/view/Binaries/job/postgis-
binaries/326/architecture=amd64,distribution=sid/console
The sympton is always that the diff shows some rows missing.
I managed to track it down to shp2pgsql sometimes missing the INSERT part;
running it in a loop will eventually trigger the bug.
while ./loader/shp2pgsql -G -g the_geom ./regress/loader/MultiPointZ.shp
loadedshp | grep INSERT; do :; done
Shapefile type: MultiPointZ
Postgis type: MULTIPOINT[4]
INSERT INTO "loadedshp" (the_geom) VALUES
('01040000E0E61000000300000001010000C00000000000000000000000000000F03F0000000000000040000000000000084001010000C00000000000002240000000000000F0BF00000000000000C000000000000008C001010000C00000000000002240000000000000F0BF00000000000034C00000000000C05EC0');
<-- no INSERT here
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4994>
