[postgis-tickets] [PostGIS] #4991: st_union of single row should keep the row intact
trac at osgeo.org
Thu Sep 16 07:16:54 PDT 2021
Reporter: michal | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.5
Component: postgis | Version: 3.1.x
Resolution: invalid | Keywords:
Comment (by mdavis):
Hoo boy there's a lot of confusion going on here. Some of it is due to
slightly confusing or possibly erroneous documentation, and some is due to
(apparently) inconsistent implementation.
The key fact is that it is intentional that Union operation semantics
cause *all* lines to be nodedd, even single ones. The input line in this
case crosses itself, so it is turned into a MultiLineString.
Given this, it seems like `ST_MemUnion` may have an optimization that
avoids this semantic - which should probably be fixed, so things are
consistent.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4991#comment:4>
