[postgis-tickets] [PostGIS] #4991: st_union of single row should keep the row intact
trac at osgeo.org
Thu Sep 16 09:05:27 PDT 2021
Reporter: michal | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.5
Component: postgis | Version: 3.1.x
Resolution: invalid | Keywords:
Comment (by michal):
I do service like [https://mhd.oma.sk/-133867] where I collect data from
OSM (linestring or multilinesting), grouping by id in the OSM database.
osm2pgsql does a great job of importing and merging data, but sometimes I
have to alter the multilinestring (eg removing platforms from tram
routes). Then query like `select st_union(way) from planet_osm_line where
platform is null and osm_id=123` creates usually a linestring (and not
multilinestring). Sometimes the number of matching rows is 1, sometimes
2+. but since `st_memunion` keeps the data intact, I do not have to make
if-else before the query (which I like very, very much, please do not
change it :) ).
having linestrings allows to use `st_linelocatepoint` - so info like
'there is a bus stop named AAA after 1.5km'
in this particular linestring, it is a bus line which makes a left turn
over a bridge, so when crossing itself the Z index is different. but the Z
index is dropped during import, because it's not needed (so the postgis
data is 2D only).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4991#comment:6>
