[postgis-tickets] [PostGIS] #4991: st_union of single row should keep the row intact
trac at osgeo.org
Thu Sep 16 12:37:00 PDT 2021
Reporter: michal | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.5
Component: postgis | Version: 3.1.x
Resolution: invalid | Keywords:
Comment (by michal):
well, until today, I did no know `ST_MemUnion` exists. I should read the
docs more.
after reading docs for `ST_Union` there is no mention that it does not sew
linestrings. "Unions the input geometries, merging geometry to produce a
result geometry with no overlaps." - for me, this means that it sews
linestrings as well as polygons
`SELECT ST_AsText(ST_union( ST_GeomFromText('MULTILINESTRING((-44 -34,-45
-33),(-44 -34,-46 -32))') ));` removes the overlap but imho it should
remove the boundary between the linestrings (producing a linestring, not
multilinestring). just as it sews polygons and does not leave border
between them: `SELECT ST_AsText(ST_union(
ST_GeomFromText('MULTIPOLYGON(((-44 -34, -45 -33, -10 -10,-44 -34)),((-44
-34,-46 -32, -50 -50, -44 -34)))') ));` - the result is polygon, not
multipolygon.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4991#comment:9>
