[postgis-tickets] [PostGIS] #4999: Crash in ST_ASFlatGeobuf
PostGIS trac at osgeo.org
Mon Sep 20 18:40:07 PDT 2021
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  medium   |  Milestone:  PostGIS 3.2.0
Component:  postgis  |    Version:  master
 Keywords:           |
 SELECT ST_AsFlatGeobuf(foo1)OVER()  As result
                                                         FROM ((SELECT
 ST_GeomFromText('POINT EMPTY',4326) As the_geom
                         UNION ALL SELECT ST_GeomFromText('MULTIPOINT
                         UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON
                         UNION ALL SELECT ST_GeomFromText('LINESTRING
                         UNION ALL SELECT ST_GeomFromText('MULTILINESTRING
 EMPTY',4326) As the_geom ) ) As foo1 LIMIT 10;
 Crashes without the OVER() clause too.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4999>
