[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0alpha1-5-g97139b6
Tue Sep 21 05:51:49 PDT 2021
the project "PostGIS".
       via  97139b6e803b0588b64497cd1c60d47abb30572a (commit)
      from  d807a0faec9d6e85b9fe107e3c5b0396cef01339 (commit)
revisions in full, below.
commit 97139b6e803b0588b64497cd1c60d47abb30572a
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Sep 21 08:49:42 2021 -0400
    Test functions even if not directly in sect1 section.
    Put in OVER(ORDER BY random()) for all aggs and window functions.
    Exclude ST_AsMVT and ST_AsFlatGeobuf for now since they have known
    crashers.  Until fixed.
    References #4998 for PostGIS 3.2.
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index c896340..77ece32 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -10,7 +10,7 @@
 	<xsl:output method="text" />
 	<xsl:variable name='testversion'>3.2.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
-	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
+	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable ST_AsFlatGeobuf ST_AsMVT</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
 	<xsl:variable name='var_srid'>3395</xsl:variable>
@@ -481,7 +481,7 @@ SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing';
 	</xsl:for-each>
 <!--End test on operators -->
 <!-- Start regular function checks excluding operators -->
-		<xsl:for-each select="sect1[not(contains(@id,'Operator'))]/refentry">
+		<xsl:for-each select="sect1[not(contains(@id,'Operator'))]//refentry">
 		<xsl:sort select="@id"/>
 			<xsl:for-each select="refsynopsisdiv/funcsynopsis/funcprototype">
@@ -511,11 +511,11 @@ SELECT '<xsl:value-of select="$log_label" /> Geography: End Testing';
 				  </xsl:choose>
 				</xsl:variable>
-				<!-- is a window function -->
+				<!-- is a window or aggregate function -->
 				<xsl:variable name='over_clause'>
 					 <xsl:choose>
-					 	<xsl:when test="paramdef/type[contains(text(),'winset')]">
-					 		<xsl:value-of select="'OVER()'"/>
+					 	<xsl:when test="paramdef/type[contains(text(),'set')]">
+					 		<xsl:value-of select="'OVER(ORDER BY random())'"/>
 					 	</xsl:when>
 					<xsl:otherwise>
 					  <xsl:value-of select="''"/>
diff --git a/doc/xsl/raster_gardentest.sql.xsl b/doc/xsl/raster_gardentest.sql.xsl
index 13af0e5..83186d6 100644
--- a/doc/xsl/raster_gardentest.sql.xsl
+++ b/doc/xsl/raster_gardentest.sql.xsl
@@ -185,7 +185,7 @@ COMMIT;
 <!--Start test on operators  -->
-	<xsl:for-each select="sect1[contains(@id,'RT_Operator')]/refentry">
+	<xsl:for-each select="sect1[contains(@id,'RT_Operator')]//refentry">
 			<xsl:variable name='fnname'><xsl:value-of select="funcdef/function"/></xsl:variable>
@@ -266,6 +266,19 @@ COMMIT;
 					</xsl:otherwise>
 				  </xsl:choose>
 				</xsl:variable>
+				<xsl:variable name='over_clause'>
+					 <xsl:choose>
+					 	</xsl:when>
+					<xsl:otherwise>
+					  <xsl:value-of select="''"/>
+					</xsl:otherwise>
+				  </xsl:choose>
+				</xsl:variable>
 				SELECT 'Start Considering <xsl:value-of select="funcdef/function" /> <xsl:value-of select="$geoftype" />';
 				<!-- For each function prototype generate a test sql statement -->
@@ -296,7 +309,7 @@ SELECT  'Ending <xsl:value-of select="funcdef/function" />(<xsl:value-of select=
 	 <!-- If output is raster show ewkt convexhull rep -->
 	 		INSERT INTO <xsl:value-of select="$var_logtable" />(log_label, func, g1, log_start, log_sql)
 			  	VALUES('<xsl:value-of select="$log_label" /> <xsl:value-of select="$geoftype" /> <xsl:text> </xsl:text><xsl:value-of select="@ID" /><xsl:text> </xsl:text><xsl:value-of select="@PixType" />','<xsl:value-of select="$fnname" />', '<xsl:value-of select="@PixType" />', clock_timestamp(),
-			  		'<xsl:call-template name="escapesinglequotes"><xsl:with-param name="arg1">SELECT ST_AsEWKT(ST_ConvexHull(<xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />))) FROM (<xsl:value-of select="." />) As rast1 LIMIT 3;</xsl:with-param></xsl:call-template>'
+			  		'<xsl:call-template name="escapesinglequotes"><xsl:with-param name="arg1">SELECT ST_AsEWKT(ST_ConvexHull(<xsl:value-of select="$fnname" />(<xsl:value-of select="$fnfakeparams" />) <xsl:value-of select="$over_clause" />)) FROM (<xsl:value-of select="." />) As rast1 LIMIT 3;</xsl:with-param></xsl:call-template>'
 			  </xsl:when>
 			  <xsl:otherwise>
Summary of changes:
 doc/xsl/postgis_gardentest.sql.xsl | 10 +++++-----
 doc/xsl/raster_gardentest.sql.xsl  | 17 +++++++++++++++--
 2 files changed, 20 insertions(+), 7 deletions(-)
hooks/post-receive
