[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0alpha1-10-g5476f08
Tue Sep 21 13:10:21 PDT 2021
the project "PostGIS".
       via  5476f08d1eafe2807b206ac95197d7ce46d20549 (commit)
       via  25dc016f86904b8e6ac2f6c13712ba2c61632419 (commit)
      from  cb726d5cd6c8b6630b9862af77311921d79f61b4 (commit)
revisions in full, below.
commit 5476f08d1eafe2807b206ac95197d7ce46d20549
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Sep 21 16:10:16 2021 -0400
    Bump winnie to SFCGAL 1.4.0 and CGAL 5.3, also fix GEOS. References https://git.osgeo.org/gitea/postgis/postgis/pulls/56
diff --git a/ci/winnie/build_postgis.sh b/ci/winnie/build_postgis.sh
index 5c103d1..7b99c57 100644
--- a/ci/winnie/build_postgis.sh
+++ b/ci/winnie/build_postgis.sh
@@ -4,8 +4,8 @@ if  [[ "${OVERRIDE}" == '' ]] ; then
 	export GEOS_VER=3.9.0
 	export GDAL_VER=3.2.0
 	export PROJ_VER=7.1.1
-	export SFCGAL_VER=1.3.9
-	export CGAL_VER=5.0
+	export SFCGAL_VER=1.4.0
+	export CGAL_VER=5.3
 	export ICON_VER=1.16
 	export ZLIB_VER=1.2.11
   export PROTOBUF_VER=3.2.0
@@ -38,7 +38,7 @@ fi;
 #set to something even if override is on but not set
 if  [[ "${CGAL_VER}" == '' ]] ; then
-  export CGAL_VER=4.11
 fi;
 #export GDAL_VER=2.4.0
diff --git a/ci/winnie/package_postgis.sh b/ci/winnie/package_postgis.sh
index 125da45..b6fcd38 100644
--- a/ci/winnie/package_postgis.sh
+++ b/ci/winnie/package_postgis.sh
@@ -16,11 +16,11 @@
 #otherwise use the ones jenkins passes thru
 #!/usr/bin/env bash
-	export GEOS_VER=3.9.0
-	export GDAL_VER=3.2.0
+	export GEOS_VER=3.9.1
+	export GDAL_VER=3.2.3
@@ -53,7 +53,7 @@ fi;
 fi;
 echo "ZLIB_VER $ZLIB_VER"
diff --git a/ci/winnie/regress_postgis.sh b/ci/winnie/regress_postgis.sh
index ded2d26..e4f5d75 100644
--- a/ci/winnie/regress_postgis.sh
+++ b/ci/winnie/regress_postgis.sh
@@ -1,11 +1,11 @@
 #!/usr/bin/env bash
 set -e
-	export CGAL_VER=5.0.2
+	export CGAL_VER=5.3.0
 	export ICON_VER=1.15
 fi;
@@ -135,9 +135,9 @@ fi
 if [ -n "$SFCGAL_VER" ]; then
 	##hard code versions of cgal etc. for now
 	#export CGAL_VER=4.11
-	BOOST_VER=1.59.0
+	BOOST_VER=1.73.0
 	#BOOST_VER_WU=1_49_0
-	export BOOST_VER_WU=1_59_0
+	export BOOST_VER_WU=1_73_0
 	export PATH="${PROJECTS}/CGAL/rel-cgal-${CGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/CGAL/rel-sfcgal-${SFCGAL_VER}w${OS_BUILD}${GCC_TYPE}/bin:${PROJECTS}/boost/rel-${BOOST_VER_WU}w${OS_BUILD}${GCC_TYPE}/lib:${PATH}"
commit 25dc016f86904b8e6ac2f6c13712ba2c61632419
Date:   Tue Sep 21 16:06:30 2021 -0400
    Add back ST_AsFlatGeobuf now that it is passing
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index 77ece32..b7de9b2 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -10,7 +10,7 @@
 	<xsl:output method="text" />
 	<xsl:variable name='testversion'>3.2.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
-	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable ST_AsFlatGeobuf ST_AsMVT</xsl:variable>
+	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable ST_AsMVT</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
 	<xsl:variable name='var_srid'>3395</xsl:variable>
Summary of changes:
 ci/winnie/build_postgis.sh         |  6 +++---
 ci/winnie/package_postgis.sh       | 10 +++++-----
 ci/winnie/regress_postgis.sh       | 12 ++++++------
 doc/xsl/postgis_gardentest.sql.xsl |  2 +-
 4 files changed, 15 insertions(+), 15 deletions(-)
hooks/post-receive
