[postgis-tickets] [PostGIS] #4990: getfacecontainingpoint fails on i386
PostGIS trac at osgeo.org
Wed Sep 22 12:45:29 PDT 2021
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.2.0
 Component:  topology        |    Version:  master
Resolution:                  |   Keywords:
Comment (by strk):
 The only idea I have about this problem is one of alignment. I'm using {{{
 getPoint2d_cp }}} for accessing the points, which is known to only work
 when the pointlist is aligned to the double boundary, which is documented
 to happen when the POINTARRAY comes from deserialization.
 Chances are that we are NOT ensuring double alignment when creating
 geometries like shortestLine, and this is making the code unstable.
 Enabling debugging by uncommenting the POSTGIS_DEBUG_LEVEL in
 liblwgeom/lwgeom_topo.c should reveal this.
 I can send a candidate patch but I need a way to reproduce it to test it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4990#comment:8>
