[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0alpha1-20-g6e14d0a
git at osgeo.org
git at osgeo.org
Thu Sep 23 16:01:06 PDT 2021
the project "PostGIS".
via 6e14d0a902d76a9c49ba178749a5968a0f6017f6 (commit)
from f48c4a86a95203b06e05557d26145b2adf85923b (commit)
revisions in full, below.
commit 6e14d0a902d76a9c49ba178749a5968a0f6017f6
Author: Martin Davis <mtnclimb at gmail.com>
Date: Thu Sep 23 16:01:01 2021 -0700
Improve doc Geometry model section
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index 761c06a..b17da9c 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -11,21 +11,44 @@
<para>The Open Geospatial Consortium (OGC) developed the
<ulink url="https://www.ogc.org/standards/sfa"><emphasis>Simple Features Access</emphasis></ulink>
standard (SFA) to provide a model for geospatial data.
- It defines the fundamental spatial data type of Geometry, with
- a set of subtypes that represent various kinds and dimensions of geometric shapes.
+ It defines the fundamental spatial datatype of <emphasis role="bold">Geometry</emphasis>,
+ along with operations which manipulate and transform geometry values
+ to perform spatial analysis tasks.
+ PostGIS implements the OGC Geometry model as the PostgreSQL data types
+ <link linkend="PostGIS_Geometry">geometry</link> and
+ <link linkend="PostGIS_Geography">geography</link>.
+ </para>
+ <para>
+ Geometry is an <emphasis>abstract</emphasis> datatype,
+ so geometry values always belong to one of the <emphasis>concrete</emphasis> subtypes
+ which represent various kinds and dimensions of geometric shapes.
+ These include the <emphasis role="bold">atomic</emphasis> types
+ <link linkend="Point">Point</link>,
+ <link linkend="LineString">LineString</link>,
+ <link linkend="LinearRing">LinearRing</link> and
+ <link linkend="Polygon">Polygon</link>,
+ and the <emphasis role="bold">collection</emphasis> types
+ <link linkend="MultiPoint">MultiPoint</link>,
+ <link linkend="MultiLineString">MultiLineString</link>,
+ <link linkend="MultiPolygon">MultiPolygon</link> and
+ <link linkend="GeometryCollection">GeometryCollection</link>.
The <ulink url="https://portal.ogc.org/files/?artifact_id=25355"><emphasis>Simple Features Access - Part 1: Common architecture v1.2.1</emphasis></ulink>
- adds subtypes for the geometric objects PolyhedralSurfaces, Triangles and TINs.
+ adds subtypes for the structures
+ <link linkend="PolyhedralSurface">PolyhedralSurface</link>,
+ <link linkend="Triangle">Triangle</link> and
+ <link linkend="TIN">TIN</link>.
</para>
- <para>The geometry types model shapes on the 2-dimensional Cartesian plane
- constructed from points and line segments.
+ <para>The geometry types model shapes in the 2-dimensional Cartesian plane
+ (the PolyhedralSurface, Triangle, and TIN types also allow values in 3-dimensional space).
The size and location of shapes are specified by their <emphasis role="bold">coordinates</emphasis>.
- The points and line segments are defined by one or two coordinates in the plane.
- Each coordinate has a X and Y value determining its location in the plane.
+ Each coordinate has a X and Y <emphasis role="bold">ordinate</emphasis> value determining its location in the plane.
+ Shapes are constructed from points or line segments, with points specified by a single coordinate,
+ and line segments by two coordinates.
</para>
<para>Coordinates may contain optional Z and M ordinate values.
- The Z ordinate is usually used to represent elevation.
+ The Z ordinate is often used to represent elevation.
The M ordinate contains a measure value, which may represent time or distance.
If Z or M values are present in a geometry value, they must be defined for each point in the geometry.
If a geometry has Z or M ordinates the <emphasis role="bold">coordinate dimension</emphasis> is 3D;
@@ -42,7 +65,7 @@
while in <emphasis role="bold">geodetic</emphasis> systems
they represent longitude and latitude.
SRID 0 represents an infinite Cartesian plane with no units assigned to its axes.
- See also <xref linkend="spatial_ref_sys" />.
+ See <xref linkend="spatial_ref_sys" />.
</para>
<para>The geometry <emphasis role="bold">dimension</emphasis> is a property of geometry types.
@@ -56,6 +79,14 @@
or no elements (for collections).
</para>
+ <para>An important concept of geometry values is their spatial
+ <emphasis role="bold">extent</emphasis> or <emphasis role="bold">bounding box</emphasis>,
+ which the OGC model calls <emphasis role="bold">envelope</emphasis>.
+ This is the 2 or 3-dimensional box which encloses the coordinates of a geometry.
+ It is used as an efficient way to determine a geometry's
+ location in space and to check whether two geometries interact.
+ </para>
<para>The geometry model allows evaluating topological spatial relationships as
described in <xref linkend="DE-9IM" />.
To support this the concepts of
@@ -71,7 +102,7 @@
and is thus invalid).
However, PostGIS allows storing and manipulating invalid geometry values.
This allows detecting and fixing them if needed.
- See also <xref linkend="OGC_Validity" />
+ See <xref linkend="OGC_Validity" />
</para>
<sect3 id="Point">
@@ -99,9 +130,9 @@ POINT ZM (1 2 3 4)
<sect3 id="LinearRing">
<title>LinearRing</title>
- <para>A LinearRing is a LineString which is closed
- and simple.</para>
- <programlisting>LINEARRING (0 0 0,4 0 0,4 4 0,0 4 0,0 0 0)</programlisting>
+ <para>A LinearRing is a LineString which is both closed and simple.
+ The first and last points must be equal, and the line must not self-intersect.</para>
+ <programlisting>LINEARRING (0 0 0, 4 0 0, 4 4 0, 0 4 0, 0 0 0)</programlisting>
</sect3>
<sect3 id="Polygon">
@@ -109,7 +140,7 @@ POINT ZM (1 2 3 4)
<para>A Polygon is a 2-dimensional planar region,
delimited by an exterior boundary (the shell)
and zero or more interior boundaries (holes).
- The boundaries are formed by LinearRings.
+ Each boundary is a <link linkend="LinearRing">LinearRing</link>.
</para>
<programlisting>POLYGON ((0 0 0,4 0 0,4 4 0,0 4 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0))</programlisting>
</sect3>
@@ -158,13 +189,17 @@ POINT ZM (1 2 3 4)
<sect3 id="Triangle">
<title>Triangle</title>
- <para>A Triangle is a polygon defined by 3 distinct non-collinear points.</para>
+ <para>A Triangle is a polygon defined by three distinct non-collinear vertices.
+ Because a Triangle is a polygon it is specified by four coordinates,
+ with the first and fourth being equal.
+ </para>
<programlisting>TRIANGLE ((0 0, 0 9, 9 0, 0 0))</programlisting>
</sect3>
- <sect3 id="Tin">
+ <sect3 id="TIN">
<title>TIN</title>
- <para>A TIN is a collection of non-overlapping Triangles representing a
+ <para>A TIN is a collection of non-overlapping
+ <link linkend="Triangle">Triangle</link>s representing a
<ulink url="https://en.wikipedia.org/wiki/Triangulated_irregular_network">Triangulated Irregular Network</ulink>.
</para>
<programlisting>TIN Z ( ((0 0 0, 0 0 1, 0 1 0, 0 0 0)), ((0 0 0, 0 1 0, 1 1 0, 0 0 0)) )</programlisting>
@@ -261,7 +296,7 @@ CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0)</programlisting>
<sect2 id="OpenGISWKBWKT">
<title>WKT and WKB</title>
- <para>The OGC SFA specification defines two standard formats for representing
+ <para>The OGC SFA specification defines two formats for representing
geometry values for external use: Well-Known Text (WKT) and Well-Known
Binary (WKB). Both WKT and WKB include information about the type
of the object and the coordinates which define it.</para>
@@ -339,7 +374,7 @@ geometry = ST_GeomFromText(text WKT, SRID);</programlisting>
<programlisting>INSERT INTO geotable ( geom, name )
VALUES ( ST_GeomFromText('POINT(-126.4 45.32)', 312), 'A Place');</programlisting>
- <para>Well-Known Binary (WKB) provides a portable, faithful representation
+ <para>Well-Known Binary (WKB) provides a portable, full-precision representation
of spatial data as binary data (arrays of bytes).
Examples of the WKB representations of spatial objects are:</para>
@@ -417,7 +452,7 @@ geometry = ST_GeomFromWKB(bytea WKB, SRID);
<para>OGC SFA specifications initially supported only 2D geometries,
and the geometry SRID is not included in the input/output representations.
The OGC SFA specification 1.2.1 (which aligns with the ISO 19125 standard)
- adds support for 3D (ZYZ and XYM) and 4D (XYZM) coordinates,
+ adds support for 3D (ZYZ) and measured (XYM and XYZM) coordinates,
but still does not include the SRID value.</para>
<para>Because of these limitations PostGIS defined extended EWKB and EWKT formats.
@@ -2034,10 +2069,8 @@ WHERE
<para>The B-tree index method commonly used for attribute data
is not very useful for spatial data, since it only supports storing and querying
data in a single dimension.
- Data such as geometry which has 2 or more dimensions)
+ Data such as geometry (which has 2 or more dimensions)
requires an index method that supports range query across all the data dimensions.
- (That said, it is possible to effectively index so-called XY (point) data using a B-tree
- and explict range searches.)
One of the key advantages of PostgreSQL for spatial data handling is that it offers several kinds of
index methods which work well for multi-dimensional data: GiST, BRIN and SP-GiST indexes.</para>
Summary of changes:
doc/using_postgis_dataman.xml | 79 ++++++++++++++++++++++++++++++-------------
1 file changed, 56 insertions(+), 23 deletions(-)
hooks/post-receive
