[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0alpha1-25-g4836300
git at osgeo.org
git at osgeo.org
Fri Sep 24 17:42:51 PDT 2021
the project "PostGIS".
via 4836300b1b393effbfe7274c911a07f1c77d78d9 (commit)
from 1baf9cc491087af450abd31e161ffbd81753a51c (commit)
revisions in full, below.
commit 4836300b1b393effbfe7274c911a07f1c77d78d9
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri Sep 24 17:42:43 2021 -0700
Improve doc Geometry model and Index sections
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index a0ecd96..f88dca0 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -229,14 +229,15 @@ POINT ZM (1 2 3 4)
<title>CircularString</title>
<para>CircularString is the basic curve type, similar to a
- LineString in the linear world. A single arc segment requires three
+ LineString in the linear world. A single arc segment is specified by three
points: the start and end points (first and third) and some other
- point on the arc. The exception to this is for a closed circle,
- where the start and end points are the same. In this case the
- second point MUST be the center of the arc, ie the opposite side of
- the circle. To chain arcs together, the last point of the previous
- arc is the first point of the next arc, just like in a
- LineString. This means that a valid circular string must have an
+ point on the arc.
+ To specify a closed circle the start and end points are the same
+ and the middle point is the opposite point on the circle diameter
+ (which is the center of the arc).
+ In a sequence of arcs the end point of the previous
+ arc is the start point of the next arc, just like the segments of a LineString.
+ This means that a CircularString must have an
odd number of points greater than 1.</para>
<programlisting>CIRCULARSTRING(0 0, 1 1, 1 0)
@@ -2061,13 +2062,13 @@ WHERE
</sect1>
<sect1 id="build-indexes">
- <title>Building Spatial Indexes</title>
+ <title>Spatial Indexes</title>
- <para>Indexes make using a spatial database for large data sets
- possible. Without indexing, a search for features would require a
+ <para>Spatial indexes make using a spatial database for large data sets
+ possible. Without indexing, a search for features requires a
sequential scan of every record in the database. Indexing speeds up
searching by organizing the data into a structure which can be quickly
- traversed to find records.
+ traversed to find matching records.
</para>
<para>The B-tree index method commonly used for attribute data
is not very useful for spatial data, since it only supports storing and querying
@@ -2106,8 +2107,16 @@ WHERE
</listitem>
</itemizedlist>
- <para>For more information see the
- <ulink url="https://postgis.net/workshops/postgis-intro/indexing.html">PostGIS Workshop</ulink>,
+ <para>Spatial indexes store only the bounding box of geometries.
+ Spatial queries use the index as a <emphasis role="bold">primary filter</emphasis>
+ to quickly determine a set of geometries potentially matching the query condition.
+ Most spatial queries require a <emphasis role="bold">secondary filter</emphasis>
+ that uses a spatial predicate function to test a more specific spatial condition.
+ For more information on queying with spatial predicates see <xref linkend="using-query-indexes" />.
+ </para>
+ <para>See also the
+ <ulink url="https://postgis.net/workshops/postgis-intro/indexing.html">PostGIS Workshop section on spatial indexes</ulink>,
and the <ulink url="https://www.postgresql.org/docs/current/indexes.html">PostgreSQL manual</ulink>.
</para>
diff --git a/doc/using_postgis_query.xml b/doc/using_postgis_query.xml
index 407c50b..ee60114 100644
--- a/doc/using_postgis_query.xml
+++ b/doc/using_postgis_query.xml
@@ -529,6 +529,10 @@ WHERE ST_DWithin( geom, 'SRID=312;POINT(100000 200000)', 100 )
The actual distance is then computed to confirm whether to include the record in the result set.
</para>
+ <para>For more information and examples see the
+ <ulink url="https://postgis.net/workshops/postgis-intro/indexing.html">PostGIS Workshop</ulink>.
+ </para>
</sect1>
<sect1 id="examples_spatial_sql">
Summary of changes:
doc/using_postgis_dataman.xml | 35 ++++++++++++++++++++++-------------
doc/using_postgis_query.xml | 4 ++++
2 files changed, 26 insertions(+), 13 deletions(-)
hooks/post-receive
