[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0alpha1-27-gb6cce01
git at osgeo.org
git at osgeo.org
Mon Sep 27 00:08:59 PDT 2021
the project "PostGIS".
The branch, main has been updated
via b6cce01cdaf6d31169d73871c374cae332f66992 (commit)
from 894916e50a63091b8c7e5fb641892379eda559c7 (commit)
revisions in full, below.
commit b6cce01cdaf6d31169d73871c374cae332f66992
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Sep 27 09:08:21 2021 +0200
Simplify closest_point_on_segment code, add unit test
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index ee0ab76..a6299b6 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -731,6 +731,108 @@ static void test_ptarray_closest_segment_2d()
lwline_free(line);
+static void test_ptarray_closest_point_on_segment(void)
+ LWLINE *line;
+ double loc, dist;
+ POINT4D s0, s1, qp, cp;
+ s0.x = s0.y = 0; s0.z = 10; s0.m = 20;
+ s1.x = 0; s1.y = 10; s1.z = 0; s1.m = 10;
+ /* Closest is bottom point */
+ qp.x = -0.1; qp.y = 0;
+ closest_point_on_segment(&qp, &s0, &s1, &cp);
+ ASSERT_DOUBLE_EQUAL(cp.x, 0);
+ ASSERT_DOUBLE_EQUAL(cp.y, 0);
+ ASSERT_DOUBLE_EQUAL(cp.z, 10);
+ ASSERT_DOUBLE_EQUAL(cp.m, 20);
+ qp.x = 0.1; qp.y = 0;
+ qp.x = 0; qp.y = -0.1;
+ /* Closest is top point */
+ qp.x = 0; qp.y = 10.1;
+ ASSERT_DOUBLE_EQUAL(cp.y, 10);
+ ASSERT_DOUBLE_EQUAL(cp.z, 0);
+ ASSERT_DOUBLE_EQUAL(cp.m, 10);
+ qp.x = 0.1; qp.y = 10;
+ qp.x = -0.1; qp.y = 10;
+ /* Closest is mid point */
+ qp.x = 0.1; qp.y = 5;
+ ASSERT_DOUBLE_EQUAL(cp.y, 5);
+ ASSERT_DOUBLE_EQUAL(cp.z, 5);
+ ASSERT_DOUBLE_EQUAL(cp.m, 15);
+ qp.x = -0.1; qp.y = 5;
+ qp.x = 0.1; qp.y = 2;
+ ASSERT_DOUBLE_EQUAL(cp.y, 2);
+ ASSERT_DOUBLE_EQUAL(cp.z, 8);
+ ASSERT_DOUBLE_EQUAL(cp.m, 18);
+ qp.x = -0.1; qp.y = 2;
+ qp.x = 0.1; qp.y = 8;
+ ASSERT_DOUBLE_EQUAL(cp.y, 8);
+ ASSERT_DOUBLE_EQUAL(cp.z, 2);
+ ASSERT_DOUBLE_EQUAL(cp.m, 12);
+ qp.x = -0.1; qp.y = 8;
** Used by the test harness to register the tests in this file.
@@ -751,4 +853,5 @@ void ptarray_suite_setup(void)
PG_ADD_TEST(suite, test_ptarray_scroll);
PG_ADD_TEST(suite, test_ptarray_closest_vertex_2d);
PG_ADD_TEST(suite, test_ptarray_closest_segment_2d);
+ PG_ADD_TEST(suite, test_ptarray_closest_point_on_segment);
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 7994d60..d903d80 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -1278,12 +1278,12 @@ closest_point_on_segment(const POINT4D *p, const POINT4D *A, const POINT4D *B, P
r = ( (p->x-A->x) * (B->x-A->x) + (p->y-A->y) * (B->y-A->y) )/( (B->x-A->x)*(B->x-A->x) +(B->y-A->y)*(B->y-A->y) );
- if (r<0)
+ if (r<=0)
*ret = *A;
return;
- if (r>1)
+ if (r>=1)
*ret = *B;
return;
Summary of changes:
liblwgeom/cunit/cu_ptarray.c | 103 +++++++++++++++++++++++++++++++++++++++++++
liblwgeom/ptarray.c | 4 +-
2 files changed, 105 insertions(+), 2 deletions(-)
hooks/post-receive
