[postgis-tickets] [PostGIS] #4990: getfacecontainingpoint fails on i386
PostGIS trac at osgeo.org
Mon Sep 27 01:58:28 PDT 2021
  Reporter:  Bas Couwenberg  |      Owner:  strk
      Type:  defect          |     Status:  new
  Priority:  medium          |  Milestone:  PostGIS 3.2.0
 Component:  topology        |    Version:  master
Resolution:                  |   Keywords:
Comment (by strk):
 NOTE: the root cause of this bug is closest_point_on_segment returning 1
 instead of 0 for a query point which is colllinear to the first horizontal
 segment followed by a vertical segment. Such test has been pushed in
 commit [b6cce01cdaf6d31169d73871c374cae332f66992/git] and that test is
 still failing, on the 32bit system. May be worth another ticket to deal
 with it, if we want to consider it a bug (
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4990#comment:28>
