[postgis-tickets] [SCM] PostGIS branch gitlab-ci-32bit created. 3.2.0alpha1-30-gc39d791
git at osgeo.org
git at osgeo.org
Mon Sep 27 02:38:06 PDT 2021
the project "PostGIS".
The branch, gitlab-ci-32bit has been created
at c39d7916421b662768c2bf36057c4a68465f5692 (commit)
commit c39d7916421b662768c2bf36057c4a68465f5692
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Sep 27 11:37:12 2021 +0200
Tolerance DBL_TOLERANCE in closest_point_on_segment test
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index 60c23c7..36eb538 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -818,14 +818,14 @@ static void test_ptarray_closest_point_on_segment(void)
closest_point_on_segment(&qp, &s0, &s1, &cp);
ASSERT_DOUBLE_EQUAL(cp.x, 0);
ASSERT_DOUBLE_EQUAL(cp.y, 8);
- ASSERT_DOUBLE_EQUAL(cp.z, 2);
+ ASSERT_DOUBLE_EQUAL_TOLERANCE(cp.z, 2, DBL_EPSILON);
ASSERT_DOUBLE_EQUAL(cp.m, 12);
qp.x = -0.1; qp.y = 8;
diff --git a/liblwgeom/cunit/cu_tester.h b/liblwgeom/cunit/cu_tester.h
index ebc1681..2a55ad0 100644
--- a/liblwgeom/cunit/cu_tester.h
+++ b/liblwgeom/cunit/cu_tester.h
@@ -35,6 +35,12 @@ typedef void (*PG_SuiteSetup)(void);
CU_ASSERT_EQUAL(o,(double)e); \
} while (0);
+#define ASSERT_DOUBLE_EQUAL_TOLERANCE(o,e,t) do { \
+ if ( o != e ) \
+ fprintf(stderr, "[%s:%d]\n Expected: %g\n Obtained: %g\n Tolerated: %.15g\n", __FILE__, __LINE__, (double)(e), (o), (t)); \
+ CU_ASSERT_DOUBLE_EQUAL(o,e,t); \
+} while (0);
#define ASSERT_INT_EQUAL(o,e) do { \
if ( o != e ) \
fprintf(stderr, "[%s:%d]\n Expected: %d\n Obtained: %d\n", __FILE__, __LINE__, (e), (o)); \
commit 6bf2d66482009a010ea8a739082b750fc97d8f63
Date: Mon Sep 27 11:20:38 2021 +0200
[gitlab-ci] Add i386 testing
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml
index eb3f9b1..478dbc7 100644
--- a/.gitlab-ci.yml
+++ b/.gitlab-ci.yml
@@ -25,3 +25,31 @@ test:
- make install
- RUNTESTFLAGS=-v make installcheck
- RUNTESTFLAGS="-v --dumprestore" make installcheck
+test-buster-i386:
+ image: i386/debian:buster
+ except:
+ - main
+ script:
+ - apt-get update -qq && apt-get install -y
+ bison flex
+ postgresql-11 postgresql-server-dev-11
+ build-essential autoconf libtool libcunit1-dev
+ xsltproc docbook-xsl docbook-mathml dblatex
+ libproj-dev libgdal-dev libgeos-dev libjson-c-dev
+ libprotobuf-c1 libprotobuf-c-dev protobuf-c-compiler
+ - lsb_release -a
+ - uname -a
+ - service postgresql start
+ - su -l postgres -c "createuser -s `whoami`"
+ - ./autogen.sh
+ - ./configure
+ - make maintainer-clean
+ - ./autogen.sh
+ - ./configure CFLAGS="-Wall -fno-omit-frame-pointer -Werror"
+ - make
+ - RUNTESTFLAGS=-v make check
+ - RUNTESTFLAGS="-v --dumprestore" make check-regress
+ - make install
+ - RUNTESTFLAGS=-v make installcheck
+ - RUNTESTFLAGS="-v --dumprestore" make installcheck
hooks/post-receive
