[postgis-tickets] [PostGIS] #5004: ptarray_closest_segment2d fails on 32bit (sometimes)
trac at osgeo.org
Mon Sep 27 09:23:58 PDT 2021
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Keywords: |
I've added a test for ptarray_closest_segment_2d in
[894916e50a63091b8c7e5fb641892379eda559c7/git] which is passing in gitlab-
ci test32 but failing on my own 32bit chroot.
The test invokes the function with an L-shaped linestring and a point
collinear with on of the two segments, and closest to the common vertex.
One would expect (and the test expects) that the "closest segment" found
is the first one, as the actual closest point is the shared vertex, but
under some circumstances, on a 32bit system, the code finds the second
segment to be "closer" than the first one.
By "some circumstances" I also mean *printing* or not the distance values
as found, so this screams "number of bits used for computation", using
registers or not, optimization used or not.
I'm not sure what to do with this ticket, but if we want to GUARANTEE that
the earliest segment is returned, when the closest point is a vertex, then
we need some action here, other than disabling the test.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5004>
