[postgis-tickets] [PostGIS] #5002: liblwgeom builds with no warning flags by default
trac at osgeo.org
Mon Sep 27 09:55:03 PDT 2021
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.0
Component: build/upgrade/install | Version: master
Resolution: | Keywords:
Comment (by Algunenano):
> I think we want all warnings enabled by default, as it happens under
postgis/
That's not correct. As you mentioned later, postgis/ gets any extra flags
declared by postgresql, so your '-Wall' likely comes from Postgresql
compilation.
> Algunenano do you agree to re-add -Wall to CFLAGS ?
I'm not against it as long as it's added everywhere, that is, to all build
files and not only to certain folders.
Have you considered setting up your environment variables to match your
development requirements? For example, my CFLAGS look something like this:
-march=native -mtune=native -O3 -pipe -fno-plt -fexceptions
-Wp,-D_FORTIFY_SOURCE=2 -Wformat -Werror=format-security -fstack-clash-
protection -fcf-protection -Wall -Wextra -Wno-unused-parameter -g3 -gdwarf
-fno-omit-frame-pointer -mno-omit-leaf-frame-pointer
And whenever I build a project (Postgis or any other) I use those flags. I
don't have to depend on whether autotools, cmake or whatever is used by
the project, sets warnings or not, only how to pass my flags.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5002#comment:4>
