[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0alpha1-33-g71e5d2c
git at osgeo.org
git at osgeo.org
Mon Sep 27 10:44:44 PDT 2021
the project "PostGIS".
The branch, main has been updated
via 71e5d2cfce41904c6eb5c51091d3b8e3d1478b50 (commit)
from 1ffff63a65cf3bc6064de5266175fbff3ba71955 (commit)
revisions in full, below.
commit 71e5d2cfce41904c6eb5c51091d3b8e3d1478b50
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Sep 27 19:36:45 2021 +0200
Enable -Wall by default and fix a warning reported by 10.3 with it
diff --git a/configure.ac b/configure.ac
index d44af90..3532805 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1132,6 +1132,9 @@ dnl
AC_ARG_ENABLE([debug], AC_HELP_STRING([--enable-debug], [Enable debugging code and flags]),
[ENABLE_DEBUG=1], [ENABLE_DEBUG=0])
+dnl Add -Wall to CFLAGS
+AC_LIBTOOL_COMPILER_OPTION([if $compiler supports -Wall], [_cv_wall], [-Wall], [], [CFLAGS="$CFLAGS -Wall"], [])
if test $ENABLE_DEBUG -eq 1; then
AC_DEFINE([PARANOIA_LEVEL], [10], [Enable use of memory checks])
CFLAGS="$CFLAGS -g"
diff --git a/liblwgeom/lwgeom_geos_clean.c b/liblwgeom/lwgeom_geos_clean.c
index fdbe3e8..91430d0 100644
--- a/liblwgeom/lwgeom_geos_clean.c
+++ b/liblwgeom/lwgeom_geos_clean.c
@@ -957,7 +957,8 @@ lwgeom_make_valid_params(LWGEOM* lwgeom_in, char* make_valid_params)
const char *value;
char *param_list[OPTION_LIST_SIZE];
char param_list_text[OPTION_LIST_SIZE];
- strncpy(param_list_text, make_valid_params, OPTION_LIST_SIZE);
+ strncpy(param_list_text, make_valid_params, OPTION_LIST_SIZE-1);
+ param_list_text[OPTION_LIST_SIZE-1] = '\0'; /* ensure null-termination */
memset(param_list, 0, sizeof(param_list));
option_list_parse(param_list_text, param_list);
GEOSMakeValidParams *params = GEOSMakeValidParams_create();
Summary of changes:
configure.ac | 3 +++
liblwgeom/lwgeom_geos_clean.c | 3 ++-
2 files changed, 5 insertions(+), 1 deletion(-)
hooks/post-receive
