[postgis-tickets] [SCM] PostGIS branch main updated. 3.2.0alpha1-35-gb58c971
git at osgeo.org
git at osgeo.org
Mon Sep 27 14:07:46 PDT 2021
the project "PostGIS".
The branch, main has been updated
via b58c9714bfe3f5748a932de8a1f890c7a1446d1d (commit)
from fbc4c1e66b69c8395d48b1ca07b426aec7586bf7 (commit)
revisions in full, below.
commit b58c9714bfe3f5748a932de8a1f890c7a1446d1d
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Sep 27 23:06:18 2021 +0200
Print ring identifier for 'face has multiple shells' error
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 82dca61..c2ad76d 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -483,7 +483,7 @@ BEGIN
SELECT ring_id, geom as ring_geom, side_faces
FROM all_rings_with_ring_geom
- LOOP --{
+ LOOP --}{
found_rings := found_rings + 1;
@@ -546,7 +546,7 @@ BEGIN
EXCEPTION WHEN unique_violation THEN
retrec.error = 'face has multiple shells';
retrec.id1 = rec.side_faces[1];
- retrec.id2 = NULL;
+ retrec.id2 = rec.ring_id;
RETURN NEXT retrec;
END;
ELSE -- }{ It's an hole (CW)
diff --git a/topology/test/regress/validatetopology_expected b/topology/test/regress/validatetopology_expected
index 4b98f6d..182e216 100644
--- a/topology/test/regress/validatetopology_expected
+++ b/topology/test/regress/validatetopology_expected
@@ -20,7 +20,7 @@
#4944|mixed face labeling in ring|-21|
#4944|mixed face labeling in ring|-19|
#4945|---||
-#4945|face has multiple shells|3|
+#4945|face has multiple shells|3|-17
#4830.1|---||
#4830.1|hole not in advertised face|-25|
#4830.2|---||
Summary of changes:
topology/sql/manage/ValidateTopology.sql.in | 4 ++--
topology/test/regress/validatetopology_expected | 2 +-
2 files changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
