[postgis-tickets] [PostGIS] #5006: ST_Transform: Support PROJ pipelines
trac at osgeo.org
Thu Sep 30 05:35:28 PDT 2021
Reporter: cdestigter | Owner: strk
Type: enhancement | Status: assigned
Priority: medium | Milestone: PostGIS Fund Me
Component: liblwgeom | Version: master
Resolution: | Keywords: proj
Comment (by rouault):
> @rouault is un-overloading proj_create() maybe a sensible API
progression for Proj? To differentiate "EPSG:1234 and I want a CRS" from
"EPSG:1234 and I want a transformation"? ie: "I expect an object of type X
from this string".
This is
https://proj.org/development/reference/functions.html#c.proj_create_from_database
where you specify (authority_name, code, object_type).
> But if the pipeline was specified as
urn:ogc:def:coordinateOperation:EPSG::8447 Proj does know the
source/target CRS and it'll work?
Yes, that will work with anything that is not a PROJ pipeline string
> Is source/target CRS settable on a transformation after creating it?
No, we could potentially have a proj_alter_source_crs / target_crs to do
that, but they are not yet available
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5006#comment:7>
