[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-123-gd7287d9af
git at osgeo.org
git at osgeo.org
Thu Jan 6 22:24:14 PST 2022
the project "PostGIS".
via d7287d9afd946013476fb8c0484a1a2bd7931291 (commit)
via 1b2c2bbb50495ff0207ca4bb24aa21178bf18f19 (commit)
from 187152efe010c3d030f8b7fab392acdb47a5a543 (commit)
revisions in full, below.
commit d7287d9afd946013476fb8c0484a1a2bd7931291
Author: Regina Obe <lr at pcorp.us>
Date: Fri Jan 7 01:22:29 2022 -0500
News: sfcgal_full_version
Closes https://trac.osgeo.org/postgis/ticket/5040
Closes https://git.osgeo.org/gitea/postgis/postgis/pulls/61
diff --git a/NEWS b/NEWS
index c710b74de..27828bb65 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ PostGIS 3.3.0dev
* Enhancements *
- #5037, add convexhull 3D (Loïc Bartoletti)
+ - #5040, add postgis_sfcgal_full_version (Loïc Bartoletti)
PostGIS 3.2.0 (Olivier Courtin Edition)
2021/12/17
commit 1b2c2bbb50495ff0207ca4bb24aa21178bf18f19
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date: Mon Nov 15 14:15:46 2021 +0100
add sfcgal_full_version
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index a917e4189..e4c0685c2 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -33,15 +33,56 @@
<refsection>
<title>Description</title>
+ <para>Returns the version of SFCGAL in use</para>
<para>Availability: 2.1.0</para>
<para>&sfcgal_required;</para>
<para>&Z_support;</para>
<para>&P_support;</para>
<para>&T_support;</para>
</refsection>
+ <refsection>
+ <title>See Also</title>
+ <para><xref linkend="postgis_sfcgal_full_version" /></para>
+ </refsection>
</refentry>
+ <refentry id="postgis_sfcgal_full_version">
+ <refnamediv>
+ <refname>postgis_sfcgal_full_version</refname>
+ <refpurpose>Returns the full version of SFCGAL in use including CGAL and Boost versions</refpurpose>
+ </refnamediv>
+ <refsynopsisdiv>
+ <funcsynopsis>
+ <funcprototype>
+ <funcdef>text <function>postgis_sfcgal_full_version</function></funcdef>
+ <void/>
+ </funcprototype>
+ </funcsynopsis>
+ </refsynopsisdiv>
+ <refsection>
+ <title>Description</title>
+ <para>Returns the full version of SFCGAL in use including CGAL and Boost versions</para>
+ <para>Availability: 3.2.0</para>
+ <para>&sfcgal_required;</para>
+ <para>&Z_support;</para>
+ <para>&P_support;</para>
+ <para>&T_support;</para>
+ </refsection>
+ <refsection>
+ <para><xref linkend="postgis_sfcgal_version" /></para>
+ </refsection>
+ </refentry>
<refentry id="ST_Extrude">
<refnamediv>
diff --git a/liblwgeom/lwgeom_sfcgal.c b/liblwgeom/lwgeom_sfcgal.c
index 72ff5d45a..d49d3f93a 100644
--- a/liblwgeom/lwgeom_sfcgal.c
+++ b/liblwgeom/lwgeom_sfcgal.c
@@ -23,6 +23,7 @@
#include "lwgeom_sfcgal.h"
+#include <stdio.h>
static int SFCGAL_type_to_lwgeom_type(sfcgal_geometry_type_t type);
static POINTARRAY *ptarray_from_SFCGAL(const sfcgal_geometry_t *geom, int force3D);
@@ -36,6 +37,20 @@ lwgeom_sfcgal_version()
return version;
+#define MAX_LENGTH_SFCGAL_FULL_VERSION 50
+/* Return SFCGAL full version string */
+const char *
+lwgeom_sfcgal_full_version()
+#if POSTGIS_SFCGAL_VERSION >= 10400
+ const char *version = sfcgal_full_version();
+#else
+ char *version = (char*)malloc(MAX_LENGTH_SFCGAL_FULL_VERSION);
+ snprintf(version, MAX_LENGTH_SFCGAL_FULL_VERSION, "SFCGAL=\"%s\" CGAL=\"Unknown\" Boost=\"Unknown\"", sfcgal_version());
+#endif
+ return version;
* Mapping between SFCGAL and PostGIS types
diff --git a/liblwgeom/lwgeom_sfcgal.h b/liblwgeom/lwgeom_sfcgal.h
index bc85748c2..fa21be697 100644
--- a/liblwgeom/lwgeom_sfcgal.h
+++ b/liblwgeom/lwgeom_sfcgal.h
@@ -28,6 +28,9 @@
/* return SFCGAL version string */
const char *lwgeom_sfcgal_version(void);
+/* return SFCGAL full version string */
+const char *lwgeom_sfcgal_full_version(void);
/* Convert SFCGAL structure to lwgeom PostGIS */
LWGEOM *SFCGAL2LWGEOM(const sfcgal_geometry_t *geom, int force3D, int32_t SRID);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index b901614a2..04f11babe 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3076,7 +3076,7 @@ BEGIN
RAISE DEBUG 'Function postgis_gdal_version() not found. Is raster support enabled and rtpostgis.sql installed?';
END;
BEGIN
- SELECT @extschema at .postgis_sfcgal_version() INTO sfcgalver;
+ SELECT @extschema at .postgis_sfcgal_full_version() INTO sfcgalver;
BEGIN
SELECT @extschema at .postgis_sfcgal_scripts_installed() INTO sfcgal_scr_ver;
EXCEPTION
diff --git a/postgis/uninstall_sfcgal.sql.in b/postgis/uninstall_sfcgal.sql.in
index 095131f15..4ec220cc9 100644
--- a/postgis/uninstall_sfcgal.sql.in
+++ b/postgis/uninstall_sfcgal.sql.in
@@ -16,6 +16,8 @@ BEGIN;
DROP FUNCTION IF EXISTS postgis_sfcgal_version();
+DROP FUNCTION IF EXISTS postgis_sfcgal_full_version();
DROP FUNCTION IF EXISTS ST_3DIntersection(geom1 geometry, geom2 geometry);
DROP FUNCTION IF EXISTS ST_Tesselate(geometry);
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index 23cfc783b..777365e0f 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -99,6 +99,10 @@ handleInterrupt(int sig)
Datum postgis_sfcgal_version(PG_FUNCTION_ARGS);
+Datum postgis_sfcgal_full_version(PG_FUNCTION_ARGS);
+#endif
Datum sfcgal_from_ewkt(PG_FUNCTION_ARGS);
Datum sfcgal_area3D(PG_FUNCTION_ARGS);
Datum sfcgal_intersection3D(PG_FUNCTION_ARGS);
@@ -562,6 +566,16 @@ Datum postgis_sfcgal_version(PG_FUNCTION_ARGS)
PG_RETURN_POINTER(result);
+PG_FUNCTION_INFO_V1(postgis_sfcgal_full_version);
+ const char *ver = lwgeom_sfcgal_full_version();
+ text *result = cstring_to_text(ver);
+ PG_RETURN_POINTER(result);
+#endif
PG_FUNCTION_INFO_V1(sfcgal_is_solid);
Datum sfcgal_is_solid(PG_FUNCTION_ARGS)
diff --git a/sfcgal/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
index d5af9de3d..8de50c939 100644
--- a/sfcgal/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -27,6 +27,13 @@ CREATE OR REPLACE FUNCTION postgis_sfcgal_version() RETURNS text
AS 'MODULE_PATHNAME'
LANGUAGE 'c' IMMUTABLE;
+-- Availability: 3.2.0
+CREATE OR REPLACE FUNCTION postgis_sfcgal_full_version() RETURNS text
+ AS 'MODULE_PATHNAME'
+ LANGUAGE 'c' IMMUTABLE;
+#endif
-- Availability: 3.0.0
CREATE OR REPLACE FUNCTION postgis_sfcgal_noop(geometry)
RETURNS geometry
Summary of changes:
NEWS | 1 +
doc/reference_sfcgal.xml | 41 +++++++++++++++++++++++++++++++++++++++++
liblwgeom/lwgeom_sfcgal.c | 15 +++++++++++++++
liblwgeom/lwgeom_sfcgal.h | 3 +++
postgis/postgis.sql.in | 2 +-
postgis/uninstall_sfcgal.sql.in | 2 ++
sfcgal/lwgeom_sfcgal.c | 14 ++++++++++++++
sfcgal/sfcgal.sql.in | 7 +++++++
8 files changed, 84 insertions(+), 1 deletion(-)
hooks/post-receive
