[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-124-g70b24ce64
git at osgeo.org
git at osgeo.org
Thu Jan 6 22:49:09 PST 2022
the project "PostGIS".
via 70b24ce64e8551e4a6409dde1802d17bfb0865a3 (commit)
from d7287d9afd946013476fb8c0484a1a2bd7931291 (commit)
revisions in full, below.
commit 70b24ce64e8551e4a6409dde1802d17bfb0865a3
Author: Regina Obe <lr at pcorp.us>
Date: Fri Jan 7 01:49:04 2022 -0500
Change sfcgal_full_version to 3.3.0, missed the 3.2.0 cut. Closes https://trac.osgeo.org/postgis/ticket/5040
diff --git a/doc/reference_sfcgal.xml b/doc/reference_sfcgal.xml
index e4c0685c2..b96348bff 100644
--- a/doc/reference_sfcgal.xml
+++ b/doc/reference_sfcgal.xml
@@ -70,7 +70,7 @@
<para>Returns the full version of SFCGAL in use including CGAL and Boost versions</para>
- <para>Availability: 3.2.0</para>
+ <para>Availability: 3.3.0</para>
<para>&sfcgal_required;</para>
<para>&Z_support;</para>
<para>&P_support;</para>
diff --git a/doc/xsl/postgis_aggs_mm.xml.xsl b/doc/xsl/postgis_aggs_mm.xml.xsl
index b50d52a44..33cd4cfcf 100644
--- a/doc/xsl/postgis_aggs_mm.xml.xsl
+++ b/doc/xsl/postgis_aggs_mm.xml.xsl
@@ -1,7 +1,7 @@
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
- Copyright 2010-2021, Regina Obe
+ Copyright 2010-2022, Regina Obe
License: BSD
Purpose: This is an xsl transform that generates file postgis_aggs_mm.xml which
includes index listing of aggregate functions and mm /sql compliant functions as well as what is new in each release
@@ -483,6 +483,106 @@
<sect1 id="NewFunctions">
<title>New, Enhanced or changed PostGIS Functions</title>
+ <sect2 id="NewFunctions_3_3">
+ <title>PostGIS Functions new or enhanced in 3.3</title>
+ <para>The functions given below are PostGIS functions that were added or enhanced.</para>
+ <xsl:if test="//para[contains(text(),'Availability: 3.3')]">
+ <para>Functions new in PostGIS 3.3</para>
+ <itemizedlist>
+ <!-- Pull out the purpose section for each ref entry and strip whitespace and put in a variable to be tagged unto each function comment -->
+ <xsl:for-each select='//refentry'>
+ <xsl:sort select="refnamediv/refname"/>
+ <xsl:variable name='comment'>
+ <xsl:value-of select="normalize-space(translate(translate(refnamediv/refpurpose,'
+ </xsl:variable>
+ <xsl:variable name="refid">
+ <xsl:value-of select="@id" />
+ </xsl:variable>
+ <xsl:variable name="refname">
+ <xsl:value-of select="refnamediv/refname" />
+ </xsl:variable>
+ <!-- For each section if there is note about availability in this version -->
+ <xsl:for-each select="refsection">
+ <xsl:for-each select="para | */para">
+ <xsl:choose>
+ <xsl:when test="contains(.,'Availability: 3.3')">
+ <listitem><simpara><link linkend="{$refid}"><xsl:value-of select="$refname" /></link> - <xsl:value-of select="." /><xsl:text> </xsl:text> <xsl:value-of select="$comment" /></simpara></listitem>
+ </xsl:when>
+ </xsl:choose>
+ </xsl:for-each>
+ </xsl:for-each>
+ </xsl:for-each>
+ </itemizedlist>
+ </xsl:if>
+ <xsl:if test="//para[contains(text(),'Enhanced: 3.3')]">
+ <para>Functions enhanced in PostGIS 3.3</para>
+ <itemizedlist>
+ </xsl:variable>
+ </xsl:variable>
+ </xsl:variable>
+ <xsl:choose>
+ <xsl:when test="contains(.,'Enhanced: 3.3')">
+ </xsl:when>
+ </xsl:choose>
+ </xsl:for-each>
+ </xsl:for-each>
+ </xsl:for-each>
+ </itemizedlist>
+ </xsl:if>
+ <para>Functions changed in PostGIS 3.3</para>
+ <xsl:if test="//para[contains(text(),'Changed: 3.3')]">
+ <itemizedlist>
+ </xsl:variable>
+ </xsl:variable>
+ </xsl:variable>
+ <xsl:choose>
+ <xsl:when test="contains(.,'Changed: 3.2')">
+ </xsl:when>
+ </xsl:choose>
+ </xsl:for-each>
+ </xsl:for-each>
+ </xsl:for-each>
+ </itemizedlist>
+ </xsl:if>
+ </sect2>
<sect2 id="NewFunctions_3_2">
<title>PostGIS Functions new or enhanced in 3.2</title>
diff --git a/sfcgal/sfcgal.sql.in b/sfcgal/sfcgal.sql.in
index 8de50c939..2573f3afc 100644
--- a/sfcgal/sfcgal.sql.in
+++ b/sfcgal/sfcgal.sql.in
@@ -28,7 +28,7 @@ CREATE OR REPLACE FUNCTION postgis_sfcgal_version() RETURNS text
LANGUAGE 'c' IMMUTABLE;
#if POSTGIS_SFCGAL_VERSION >= 10400
--- Availability: 3.2.0
+-- Availability: 3.3.0
CREATE OR REPLACE FUNCTION postgis_sfcgal_full_version() RETURNS text
AS 'MODULE_PATHNAME'
Summary of changes:
doc/reference_sfcgal.xml | 2 +-
doc/xsl/postgis_aggs_mm.xml.xsl | 102 +++++++++++++++++++++++++++++++++++++++-
sfcgal/sfcgal.sql.in | 2 +-
3 files changed, 103 insertions(+), 3 deletions(-)
hooks/post-receive
