[postgis-tickets] [PostGIS] #5044: make pull-tx drops translated strings
trac at osgeo.org
Mon Jan 10 07:13:59 PST 2022
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: documentation | Version: 3.2.x
Keywords: |
As of commit [b67f6c80f24edb57fa223a2065c2255bbb346cef/git] running {{{
make pull-tx }}} results in removal of translated strings in some files.
Example:
--- a/doc/po/de/introduction.xml.po
+++ b/doc/po/de/introduction.xml.po
@@ -66,13 +66,6 @@ msgid ""
"(coverages, surfaces, networks), data source for desktop user interface
"tools for viewing and editing GIS data, and web-based access tools."
msgstr ""
-"Die PostGIS Project Develpment Group beabsichtigt durch die
Unterstützung "
-"und Weiterentwicklung von PostGIS eine hohe Funktionsvielfalt zu
erreichen. "
-"Diese soll wichtige GIS-Funktionalitäten, Kompatibilität mit den
spatialen "
-"Standards OpenGIS und SQL/MM, hochentwickelte topologische Konstrukte "
-"(Coverages, Oberflächen, Netzwerke), Datenquellen für Desktop "
-"Benutzeroberflächen zum Darstellen und Bearbeiten von GIS Daten, sowie "
-"Werkzeuge für den Zugriff via Internettechnologie beinhalten."
#. Tag: title
#: introduction.xml:21
As I just pushed to transifex after the aforementioned commit I don't
understand why would a pull drop those strings, unless someone really
logged into Transifex to remove them, which is unlikely.
Other changes are the {{{ Last-Translator }}} header, which goes to me
(probably just because I was the last pusher) and removal of some {{{
fuzzy }}} labels.
I wonder if what Transifex is doing is basically DROP the "fuzzy" strings,
not trusting them ({{{--no-fuzzy-matching}}} switch used by Transifex use
of {{{msgmerge}}} whereas our own {{{update-po}}} does not make use of
that switch?)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5044>
