[postgis-tickets] [PostGIS] #5044: make pull-tx drops translated strings
PostGIS trac at osgeo.org
Mon Jan 10 07:40:01 PST 2022
  Reporter:  strk           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  medium         |  Milestone:  PostGIS 3.3.0
 Component:  documentation  |    Version:  3.2.x
Resolution:                 |   Keywords:
Comment (by strk):
 I tried using {{{ msgmerge --no-fuzzy-matching }}} on my system but I
 still don't obtain the same result obtained from pulling from Transifex.
 Weblate still has the removed-by-transifex strings:
 https://weblate.osgeo.org/translate/postgis/introductionxml/de/?offset=&q=Develpment+Group+beabsichtigt+durch&sort_by=-priority%2Cposition&checksum=
 But also Transifex seems to know about them:
 https://www.transifex.com/postgis/postgis/translate/#de/introductionxmlpot_1/179231423?q=text%3A'coverages%2C+surfaces%2C+networks'
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5044#comment:1>
