[postgis-tickets] [PostGIS] #5046: Old postgis library needed to upgrade
trac at osgeo.org
Mon Jan 10 23:29:36 PST 2022
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.1
Component: build/upgrade/install | Version: 3.2.x
Keywords: |
I confirmed this is an issue on my system as detailed in
https://lists.osgeo.org/pipermail/postgis-users/2022-January/045186.html
If you uninstall an old version of PostGIS you were using and then install
a new version (that doesn't use the same lib file), you get this error.
SELECT postgis_extensions_upgrade();
NOTICE: Updating extension postgis from 3.1.4 to 3.2.0
ERROR: could not access file "$libdir/postgis-3": No such file or
directory
CONTEXT: PL/pgSQL function _postgis_drop_function_if_needed(text,text)
line 6 at FOR over SELECT rows
SQL statement "ALTER EXTENSION postgis UPDATE TO "3.2.0";"
PL/pgSQL function postgis_extensions_upgrade() line 79 at EXECUTE
SQL state: 58P01
I thought we had dealt with this issue before, to allow upgrade even in
absense of old library.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5046>
