[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-154-gc4bc753ca
Tue Jan 11 13:44:51 PST 2022
the project "PostGIS".
       via  c4bc753caf08046f6b39675cb07126011642e1f2 (commit)
      from  5ba18f2d49af2dc33d0d2408c248b8e2f0a1b992 (commit)
revisions in full, below.
commit c4bc753caf08046f6b39675cb07126011642e1f2
Author: strk <strk at kbt.io>
Date:   Tue Jan 11 21:31:01 2022 +0000
    Translated using Weblate (Italian)
    Currently translated at 46.1% (114 of 247 strings)
    Currently translated at 83.3% (5 of 6 strings)
    Co-authored-by: strk <strk at kbt.io>
    Translate-URL: https://weblate.osgeo.org/projects/postgis/installationxml/it/
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis/it/
    Translation: postgis/installation.xml
    Translation: postgis/postgis
diff --git a/doc/po/it_IT/installation.xml.po b/doc/po/it_IT/installation.xml.po
index faa03e41b..34fe2b184 100644
--- a/doc/po/it_IT/installation.xml.po
+++ b/doc/po/it_IT/installation.xml.po
@@ -11,15 +11,16 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2021-09-11 01:55+0000\n"
-"PO-Revision-Date: 2018-07-22 02:56+0000\n"
-"Last-Translator: georgersilva <georger.silva at gmail.com>\n"
-"Language-Team: Italian (Italy) (http://www.transifex.com/postgis/postgis/"
-"language/it_IT/)\n"
+"PO-Revision-Date: 2022-01-11 21:30+0000\n"
+"Last-Translator: strk <strk at kbt.io>\n"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
+"installationxml/it/>\n"
 "Language: it_IT\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=n != 1;\n"
+"X-Generator: Weblate 4.10.1\n"
 #. Tag: title
 #: installation.xml:3
@@ -132,7 +133,7 @@ msgid ""
 "happens. You can use these to experiment with the in progress releases of "
 "PostGIS"
 msgstr ""
-"Se siete un utente Windows, potete reperire le versioni stabili  tramite "
+"Se siete un utente Windows, potete reperire le versioni stabili tramite "
 "Stackbuilder o la pagina <ulink url=\"http://www.postgis.org/download/"
 "windows/\">PostGIS Windows download</ulink>. Inoltre potete scaricare <ulink "
 "url=\"http://www.postgis.org/download/windows/experimental.php\">le "
@@ -151,11 +152,11 @@ msgid ""
 "against PostgreSQL versions &min_postgres_version; or higher. Earlier "
 "versions of PostgreSQL are <emphasis>not</emphasis> supported."
 msgstr ""
-"Il modulo PostGIS è un'estensione del server PostgreSQL. Pertanto, +  "
+"Il modulo PostGIS è un'estensione del server PostgreSQL. Pertanto, è "
 "<emphasis>indispensabile</emphasis> che PostGIS &last_release_version; abbia "
 "pieno accesso agli header di PostgreSQL server per potersi compilare. Può "
-"essere compilato con versioni di PostgreSQL dalla  &min_postgres_version;  "
-"in su. Le versioni precedenti di PostgreSQL <emphasis>non</emphasis> sono "
+"essere compilato con versioni di PostgreSQL dalla &min_postgres_version; in "
+"su. Le versioni precedenti di PostgreSQL <emphasis>non</emphasis> sono "
 "supportate."
 #. Tag: para
@@ -240,21 +241,22 @@ msgid ""
 "This will create a directory called <varname>postgis-&last_release_version;</"
 "varname> in the current working directory."
 msgstr ""
-"Questo passaggio creerà una cartella denominata  <varname>postgis-"
-"&last_release_version;</varname> nella cartella di lavoro attuale."
+"Questo passaggio creerà una cartella denominata "
+"<varname>postgis-&last_release_version;</varname> nella cartella di lavoro "
+"attuale."
 #. Tag: para
 #: installation.xml:96
-#, fuzzy, no-c-format
+#, no-c-format
 msgid ""
 "Alternatively, checkout the source from the <ulink url=\"https://git-scm.com/"
 "\"> git </ulink> repository <ulink url=\"https://git.osgeo.org/gitea/postgis/"
 "postgis/\"> https://git.osgeo.org/gitea/postgis/postgis/ </ulink> ."
 msgstr ""
-"In alternativa, potete eseguire un checkout del sorgente dalla repository "
-"<ulink url=\"http://subversion.apache.org/\"> svn </ulink>  <ulink url="
-"\"http://svn.osgeo.org/postgis/trunk/\"> http://svn.osgeo.org/postgis/trunk/ "
-"</ulink> ."
+"In alternativa, potete ottenere una copia del sorgente dalla repository "
+"<ulink url=\"https://git-scm.com/\">git</ulink> <ulink url=\"https://git."
+"osgeo.org/gitea/postgis/postgis/\">https://git.osgeo.org/gitea/postgis/"
+"postgis/</ulink> ."
 #. Tag: programlisting
 #: installation.xml:108
@@ -300,7 +302,7 @@ msgid ""
 "from <ulink url=\"http://www.postgresql.org\"> http://www.postgresql.org </"
 "ulink> ."
 msgstr ""
-"PostgreSQL  &min_postgres_version;  o versioni superiori. E' necessaria "
+"PostgreSQL &min_postgres_version; o versioni superiori. E' necessaria "
 "un'installazione completa di PostgreSQL (compresi gli header del server). "
 "PostgreSQL è disponibile al sito <ulink url=\"http://www.postgresql.org\"> "
 "http://www.postgresql.org </ulink> ."
@@ -402,17 +404,15 @@ msgstr ""
 #. Tag: para
 #: installation.xml:206
+#, no-c-format
 msgid ""
 "If compiling with PostgreSQL+JIT, LLVM version >=6 is required <ulink url="
 "\"https://trac.osgeo.org/postgis/ticket/4125\">https://trac.osgeo.org/"
 "postgis/ticket/4125</ulink>."
 msgstr ""
-"Attualmente questo parametro non funzione, dato che il pacchetto si "
-"installerà solamente nella cartella di installazione di PostgreSQL. Potete "
-"visitare la pagina  <ulink url=\"http://trac.osgeo.org/postgis/ticket/635\"> "
-"http://trac.osgeo.org/postgis/ticket/635 </ulink> per seguire l'evoluzione "
-"di questo bug."
+"Se si compila con PostgreSQL+JIT, e' necessaria una versione di LLVM >=6 "
+"<ulink url=\"https://trac.osgeo.org/postgis/ticket/4125\">https://trac.osgeo."
+"org/postgis/ticket/4125</ulink>."
 #. Tag: emphasis
 #: installation.xml:215
@@ -616,7 +616,7 @@ msgid ""
 msgstr ""
+"visitare la pagina <ulink url=\"http://trac.osgeo.org/postgis/ticket/635\"> "
 "di questo bug."
@@ -779,11 +779,11 @@ msgstr ""
 "Normalmente PostGIS cercherà di rilevare il supporto per gettext e di "
 "utilizzarlo nella compilazione. Tuttavia, se risocontrate problemi di "
 "compatibilità che determinano interruzioni del loader, potete disabilitare "
-"il supporto con questo comando. Potete fare riferimento al ticket  <ulink "
-"url=\"http://trac.osgeo.org/postgis/ticket/748\">http://trac.osgeo.org/"
-"postgis/ticket/748</ulink> per un esempio di un caso risolto utilizzando "
-"questa particolare configurazione. NOTA: disattivanto questa opzione non vi "
-"perdete molto, dato che è utilizzata per il supporto internazionale o per le "
+"il supporto con questo comando. Potete fare riferimento al ticket <ulink url="
+"\"http://trac.osgeo.org/postgis/ticket/748\">http://trac.osgeo.org/postgis/"
+"ticket/748</ulink> per un esempio di un caso risolto utilizzando questa "
+"particolare configurazione. NOTA: disattivanto questa opzione non vi perdete "
+"molto, dato che è utilizzata per il supporto internazionale o per le "
 "etichette nel loader, che non sono ancora ben documentate e in forma "
 "sperimentale."
@@ -806,15 +806,15 @@ msgstr ""
 #. Tag: para
 #: installation.xml:529
+#, no-c-format
 msgid ""
 "If you obtained PostGIS from the <ulink url=\"https://trac.osgeo.org/postgis/"
 "wiki/CodeRepository\"> code repository </ulink> , the first step is really "
 "to run the script"
 msgstr ""
-"Se avete ottenuto PostGIS dalla  <ulink url=\"http://svn.osgeo.org/postgis/"
-"trunk/\"> repository </ulink> SVN , il primo passo consiste nell'eseguire lo "
-"script"
+"Se avete ottenuto PostGIS dalla <ulink url=\"https://trac.osgeo.org/postgis/"
+"wiki/CodeRepository\"> code repository </ulink> , il primo passo consiste "
+"nell'eseguire lo script"
 #. Tag: para
 #: installation.xml:541
@@ -895,7 +895,7 @@ msgid ""
 msgstr ""
 "Introdotto in PostGIS 2.0. Questa opzione genera degli opuscoli riassuntivi "
 "in formato HTML, utili come riferimento speditivo o per distribuzione agli "
-"studenti. Richiede xsltproc e genererà 4 file della cartella doc:  "
+"studenti. Richiede xsltproc e genererà 4 file della cartella doc: "
 "<filename>topology_cheatsheet.html</filename>, "
 "<filename>tiger_geocoder_cheatsheet.html</filename>, "
 "<filename>raster_cheatsheet.html</filename>, <filename>postgis_cheatsheet."
@@ -910,8 +910,8 @@ msgid ""
 "Guides</ulink>"
 msgstr ""
 "Ne potete scaricare alcuni già pronti sia in formato HTML che PDF dalla "
-"pagina  <ulink url=\"http://www.postgis.us/study_guides\">PostGIS / "
-"PostgreSQL Study Guides</ulink> "
+"pagina <ulink url=\"http://www.postgis.us/study_guides\">PostGIS / "
+"PostgreSQL Study Guides</ulink>"
 #. Tag: command
 #: installation.xml:592
@@ -1048,9 +1048,9 @@ msgid ""
 "<filename>extensions/postgis/sql/*.sql</filename>, <filename>extensions/"
 "postgis_topology/sql/*.sql</filename>"
 msgstr ""
-"Tutti i file nella cartella /sql di ciascuna estesnione. Da notare che quesi "
+"Tutti i file nella cartella /sql di ciascuna estensione. Da notare che quesi "
 "devono essere copiati nella cartella principale delle estensioni di "
-"PostgreSQL, share/extension  <filename>extensions/postgis/sql/*.sql</"
+"PostgreSQL, share/extension <filename>extensions/postgis/sql/*.sql</"
 "filename>, <filename>extensions/postgis_topology/sql/*.sql</filename>"
 #. Tag: para
@@ -1061,7 +1061,7 @@ msgid ""
 "<varname>postgis_topology</varname> as available extensions in PgAdmin -> "
 "extensions."
 msgstr ""
-"Una volta eseguita questa operazione, dovreste vedere  <varname>postgis</"
+"Una volta eseguita questa operazione, dovreste vedere <varname>postgis</"
 "varname>, <varname>postgis_topology</varname> come estensioni disponibili in "
 "PgAdmin -> extensions."
@@ -1218,7 +1218,7 @@ msgstr ""
 "Pertanto non modificare gli SRID facenti parte dell'installazione, "
 "aspettandovi poi di trovare le vostre modiche nel backup. Se ci sono "
 "problemi, aprite un ticket. Neanche delle strutture delle tabelle delle "
-"estensioni viene eseguito un backup, dato che sono create con  <code>CREATE "
+"estensioni viene eseguito un backup, dato che sono create con <code>CREATE "
 "EXTENSION</code>, e si presume che siano le stesse per una data versione "
 "dell'estensione. Questo comportamento è inserito nell'attuale modello delle "
 "estensioni, per cui non c'è molto che l'utente può fare."
diff --git a/doc/po/it_IT/postgis.xml.po b/doc/po/it_IT/postgis.xml.po
index 1d02975ad..0ded74984 100644
--- a/doc/po/it_IT/postgis.xml.po
+++ b/doc/po/it_IT/postgis.xml.po
@@ -9,15 +9,16 @@ msgstr ""
-"PO-Revision-Date: 2014-10-20 15:59+0000\n"
-"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
-"Language-Team: Italian (Italy) (http://www.transifex.com/projects/p/postgis/"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/postgis/"
+"it/>\n"
 "Language: it_IT\n"
 #. Tag: title
 #: postgis.xml:146
@@ -40,14 +41,10 @@ msgid ""
 "state> <country>Canada</country> <email>pramsey at cleverelephant.ca</email></"
 "address>"
 msgstr ""
-"<orgname><ulink url=\"http://www.cleverelephant.ca\">clever elephant</"
-"ulink></orgname> <address><city>Victoria</city> <state>British Columbia</"
-"state> <country>Canada</country> <email>pramsey at cleverelephant.ca</email></"
-"address>"
 #. Tag: para
 #: postgis.xml:170
+#, no-c-format
 msgid ""
 "PostGIS is an extension to the <ulink url=\"https://www.postgresql.org/"
 "\">PostgreSQL</ulink> object-relational database system which allows GIS "
@@ -55,10 +52,11 @@ msgid ""
 "PostGIS includes support for GiST-based R-Tree spatial indexes, and "
 "functions for analysis and processing of GIS objects."
 msgstr ""
-"PostGIS è un'estensione del database object-relational PostgreSQL che "
-"consente l'archiviazione di oggetti GIS (Geographic Information Systems). "
-"PostGIS comprende il supporto per gli indici spaziali R-Tree basati su GIST, "
-"e funzioni per l'analisi e l'elaborazione di oggetti GIS."
+"PostGIS è un'estensione del database object-relational <ulink url=\"https"
+"://www.postgresql.org/\">PostgreSQL</ulink> che consente l'archiviazione di "
+"oggetti GIS (Geographic Information Systems). PostGIS comprende il supporto "
+"per gli indici spaziali R-Tree basati su GiST, e funzioni per l'analisi e "
+"l'elaborazione di oggetti GIS."
 #. Tag: para
 #: postgis.xml:179
Summary of changes:
 doc/po/it_IT/installation.xml.po | 80 ++++++++++++++++++++--------------------
 doc/po/it_IT/postgis.xml.po      | 26 ++++++-------
 2 files changed, 52 insertions(+), 54 deletions(-)
hooks/post-receive
