[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-223-g3b8e21e58
git at osgeo.org
git at osgeo.org
Thu Jan 13 12:13:32 PST 2022
the project "PostGIS".
via 3b8e21e586aa649ee8c9c79814755b1d6eece148 (commit)
via 26d51b23a1f967771df731b91bba5fd5e3cd735e (commit)
from 897549055ec702cb5dc75cd93b874cfa93157bdf (commit)
revisions in full, below.
commit 3b8e21e586aa649ee8c9c79814755b1d6eece148
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 13 21:12:59 2022 +0100
Have Debbie always build localized-html
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index 28eb71868..39c7dd4c5 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -71,16 +71,7 @@ cp html/images/* images
make epub
make -e chunked-html-web 2>&1 | tee -a doc-errors.log
-if [[ "$reference" == *"master"* ]]; then #only do this for master branch because only master follows transifex
- make update-pot
- make pull-tx
- make -C po/it_IT/ local-html
- make -C po/pt_BR/ local-html
- make -C po/ja/ local-html
- make -C po/de/ local-html
- make -C po/ko_KR/ local-html
- #make pdf-localized
-fi
+make -C doc/ html-localized
package="doc-html-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.tar.gz"
commit 26d51b23a1f967771df731b91bba5fd5e3cd735e
Date: Thu Jan 13 21:09:42 2022 +0100
Drop references to Transifex, we go Weblate now
Update doc/po/README accordingly
diff --git a/HOWTO_RELEASE b/HOWTO_RELEASE
index c6b0bee49..c64f00b1b 100644
--- a/HOWTO_RELEASE
+++ b/HOWTO_RELEASE
@@ -84,10 +84,6 @@ Release procedure
4. Update code.
- - For first micro of a minor, make sure to pull the latest translations from transifex
- TODO: more detail here - there is a job on debbie for 3.1 for examples
- https://debbie.postgis.net/view/PostGIS/job/PostGIS_docs_translations_3.1
- and she's setup with an api key to pull and push translations.
- Update the README.md to reflect new to be created buildbot badges
(this should only be needed for trunk release)
- Edit README.postgis and set release date and version.
diff --git a/doc/.tx/config b/doc/.tx/config
deleted file mode 100644
index c0a798ec7..000000000
--- a/doc/.tx/config
+++ /dev/null
@@ -1,238 +0,0 @@
-[main]
-host = https://www.transifex.com
-[postgis.extras_address_standardizerxmlpot]
-file_filter = po/<lang>/extras_address_standardizer.xml.po
-source_file = po/templates/extras_address_standardizer.xml.pot
-source_lang = en
-[postgis.extras_historytablexmlpot]
-file_filter = po/<lang>/extras_historytable.xml.po
-source_file = po/templates/extras_historytable.xml.pot
-source_lang = en
-[postgis.extras_tigergeocoderxmlpot]
-file_filter = po/<lang>/extras_tigergeocoder.xml.po
-source_file = po/templates/extras_tigergeocoder.xml.pot
-source_lang = en
-[postgis.extras_topologyxmlpot]
-file_filter = po/<lang>/extras_topology.xml.po
-source_file = po/templates/extras_topology.xml.pot
-source_lang = en
-[postgis.extrasxmlpot]
-file_filter = po/<lang>/extras.xml.po
-source_file = po/templates/extras.xml.pot
-source_lang = en
-[postgis.faq_rasterxmlpot]
-file_filter = po/<lang>/faq_raster.xml.po
-source_file = po/templates/faq_raster.xml.pot
-source_lang = en
-[postgis.faqxmlpot]
-file_filter = po/<lang>/faq.xml.po
-source_file = po/templates/faq.xml.pot
-source_lang = en
-[postgis.installationxmlpot]
-file_filter = po/<lang>/installation.xml.po
-source_file = po/templates/installation.xml.pot
-source_lang = en
-[postgis.introductionxmlpot]
-file_filter = po/<lang>/introduction.xml.po
-source_file = po/templates/introduction.xml.pot
-source_lang = en
-[postgis.performance_tipsxmlpot]
-file_filter = po/<lang>/performance_tips.xml.po
-source_file = po/templates/performance_tips.xml.pot
-source_lang = en
-[postgis.postgisxmlpot]
-file_filter = po/<lang>/postgis.xml.po
-source_file = po/templates/postgis.xml.pot
-source_lang = en
-[postgis.reference_accessorxmlpot]
-file_filter = po/<lang>/reference_accessor.xml.po
-source_file = po/templates/reference_accessor.xml.pot
-source_lang = en
-[postgis.reference_constructorxmlpot]
-file_filter = po/<lang>/reference_constructor.xml.po
-source_file = po/templates/reference_constructor.xml.pot
-source_lang = en
-[postgis.reference_editorxmlpot]
-file_filter = po/<lang>/reference_editor.xml.po
-source_file = po/templates/reference_editor.xml.pot
-source_lang = en
-[postgis.reference_exceptionxmlpot]
-file_filter = po/<lang>/reference_exception.xml.po
-source_file = po/templates/reference_exception.xml.pot
-source_lang = en
-[postgis.reference_gucxmlpot]
-file_filter = po/<lang>/reference_guc.xml.po
-source_file = po/templates/reference_guc.xml.pot
-source_lang = en
-[postgis.reference_lrsxmlpot]
-file_filter = po/<lang>/reference_lrs.xml.po
-source_file = po/templates/reference_lrs.xml.pot
-source_lang = en
-[postgis.reference_managementxmlpot]
-file_filter = po/<lang>/reference_management.xml.po
-source_file = po/templates/reference_management.xml.pot
-source_lang = en
-[postgis.reference_measurexmlpot]
-file_filter = po/<lang>/reference_measure.xml.po
-source_file = po/templates/reference_measure.xml.pot
-source_lang = en
-[postgis.reference_sfcgalxmlpot]
-file_filter = po/<lang>/reference_sfcgal.xml.po
-source_file = po/templates/reference_sfcgal.xml.pot
-source_lang = en
-[postgis.reference_operatorxmlpot]
-file_filter = po/<lang>/reference_operator.xml.po
-source_file = po/templates/reference_operator.xml.pot
-source_lang = en
-[postgis.reference_outputxmlpot]
-file_filter = po/<lang>/reference_output.xml.po
-source_file = po/templates/reference_output.xml.pot
-source_lang = en
-[postgis.reference_processingxmlpot]
-file_filter = po/<lang>/reference_processing.xml.po
-source_file = po/templates/reference_processing.xml.pot
-source_lang = en
-[postgis.reference_rasterxmlpot]
-file_filter = po/<lang>/reference_raster.xml.po
-source_file = po/templates/reference_raster.xml.pot
-source_lang = en
-[postgis.reference_transactionxmlpot]
-file_filter = po/<lang>/reference_transaction.xml.po
-source_file = po/templates/reference_transaction.xml.pot
-source_lang = en
-[postgis.reference_typexmlpot]
-file_filter = po/<lang>/reference_type.xml.po
-source_file = po/templates/reference_type.xml.pot
-source_lang = en
-[postgis.referencexmlpot]
-file_filter = po/<lang>/reference.xml.po
-source_file = po/templates/reference.xml.pot
-source_lang = en
-[postgis.release_notesxmlpot]
-file_filter = po/<lang>/release_notes.xml.po
-source_file = po/templates/release_notes.xml.pot
-source_lang = en
-[postgis.reportingxmlpot]
-file_filter = po/<lang>/reporting.xml.po
-source_file = po/templates/reporting.xml.pot
-source_lang = en
-[postgis.using_postgis_appxmlpot]
-file_filter = po/<lang>/using_postgis_app.xml.po
-source_file = po/templates/using_postgis_app.xml.pot
-source_lang = en
-[postgis.using_postgis_datamanxmlpot]
-file_filter = po/<lang>/using_postgis_dataman.xml.po
-source_file = po/templates/using_postgis_dataman.xml.pot
-source_lang = en
-[postgis.using_postgis_querypot]
-file_filter = po/<lang>/using_postgis_query.xml.po
-source_file = po/templates/using_postgis_query.xml.pot
-source_lang = en
-[postgis.using_raster_datamanxmlpot]
-file_filter = po/<lang>/using_raster_dataman.xml.po
-source_file = po/templates/using_raster_dataman.xml.pot
-source_lang = en
-[postgis.reference_bboxxmlpot]
-file_filter = po/<lang>/reference_bbox.xml.po
-source_file = po/templates/reference_bbox.xml.pot
-source_lang = en
-[postgis.reference_clusterxmlpot]
-file_filter = po/<lang>/reference_cluster.xml.po
-source_file = po/templates/reference_cluster.xml.pot
-source_lang = en
-[postgis.reference_inputxmlpot]
-file_filter = po/<lang>/reference_input.xml.po
-source_file = po/templates/reference_input.xml.pot
-source_lang = en
-[postgis.reference_relationshipxmlpot]
-file_filter = po/<lang>/reference_relationship.xml.po
-source_file = po/templates/reference_relationship.xml.pot
-source_lang = en
-[postgis.reference_srsxmlpot]
-file_filter = po/<lang>/reference_srs.xml.po
-source_file = po/templates/reference_srs.xml.pot
-source_lang = en
-[postgis.reference_trajectoryxmlpot]
-file_filter = po/<lang>/reference_trajectory.xml.po
-source_file = po/templates/reference_trajectory.xml.pot
-source_lang = en
-[postgis.reference_transformationxmlpot]
-file_filter = po/<lang>/reference_transformation.xml.po
-source_file = po/templates/reference_transformation.xml.pot
-source_lang = en
-[postgis.reference_troubleshootingxmlpot]
-file_filter = po/<lang>/reference_troubleshooting.xml.po
-source_file = po/templates/reference_troubleshooting.xml.pot
-source_lang = en
-[postgis.reference_validationxmlpot]
-file_filter = po/<lang>/reference_validation.xml.po
-source_file = po/templates/reference_validation.xml.pot
-source_lang = en
-[postgis.reference_versionxmlpot]
-file_filter = po/<lang>/reference_version.xml.po
-source_file = po/templates/reference_version.xml.pot
-source_lang = en
-[postgis.administrationxmlpot]
-file_filter = po/<lang>/administration.xml.po
-source_file = po/templates/administration.xml.pot
-source_lang = en
-[postgis.database_tuningxmlpot]
-file_filter = po/<lang>/database_tuning.xml.po
-source_file = po/templates/database_tuning.xml.pot
-source_lang = en
-[postgis.reference_overlayxmlpot]
-file_filter = po/<lang>/reference_overlay.xml.po
-source_file = po/templates/reference_overlay.xml.pot
-source_lang = en
-[postgis.using_postgis_queryxmlpot]
-source_lang = en
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 003292921..fc67aec1f 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -206,24 +206,6 @@ update-po: $(XML_INPUTS_POT)
done
endif
-pull-tx:
- tx pull --all
- $(MAKE) update-po
-push-tx:
- tx push -s -t --skip
-# Register transifex resources, run when adding a new .xml file
-update-tx:
- for f in $(XML_INPUTS_POT); do \
- f=`basename $${f} .pot`; \
- res=`echo "$${f}" | sed 's/\.//g'`pot; \
- tx set --auto-local -r postgis.$${res} "po/<lang>/$${f}.po" \
- --source-lang en --source-file "po/templates/$${f}.pot" \
- --execute; \
- done
ifeq ($(XSLTPROC),)
postgis_aggs_mm.xml: requirements_not_met_xsltproc
else
diff --git a/doc/po/README b/doc/po/README
index 2293f0120..d2b16e964 100644
--- a/doc/po/README
+++ b/doc/po/README
@@ -33,54 +33,17 @@ Adding new languages implies (relative to doc/ dir):
- Add to the git repository the changes in the Makefile.in
and all the new files in the po/<newlanguage>/
-Using transifex
-Transifex web-ui to translation was setup here:
-https://www.transifex.com/projects/p/postgis
-Run ``make update-tx`` from the parent (doc) directory to
-update the transifex command-line tool configuration,
-found in ../.tx/config (only needed when new doc sources
-are added);
-Run ``make pull-tx`` to import remotely updated translations
-and ``make push-tx`` to upload the locally update ones, after
-making sure they are well-formed (``make html-localized`` succeeds).
-NOTE: the recommended workflow is:
- make pull-tx
- do:
- make html-localized || edit
- until success
- if edits:
- make push-tx
- make pull-tx
- commit changes to repo
- fi
-Using weblate [EXPERIMENTAL]
+Using weblate
Weblate web-ui to translation was setup here:
https://weblate.osgeo.org/projects/postgis
Translations made via Weblate will automatically be pushed
-to the a configured repository (currently robe's fork) with
-'weblate' as a committer, see commit 2d5247b0c as an example.
-Changes to the templates should be automatically fetched by Weblate
-via webhook, see https://git.osgeo.org/gitea/postgis/postgis/settings/hooks
-(currently broken because the configured repository does not match the
-URL of the official repository)
-Local changes to the translation files can be uploaded manually
-to weblate with a command like the following:
- wlc upload \
- postgis/introductionxml/it \
- --input po/it_IT/introduction.xml.po
+to the master branch of the official repository.
-NOTE: wlc 1.2 is known to be not functional, while wlc 1.12
- (current latest when installed via pip) seems fine
+Translation directly pushed to the master branch of the
+official reporitory will be automatically pulled by Weblate,
+as well as changes to the templates (.pot files).
+Pulling is triggered by a webhook, see
+https://git.osgeo.org/gitea/postgis/postgis/settings/hooks
Summary of changes:
HOWTO_RELEASE | 4 -
ci/debbie/postgis_release_docs.sh | 11 +-
doc/.tx/config | 238 --------------------------------------
doc/Makefile.in | 18 ---
doc/po/README | 53 ++-------
5 files changed, 9 insertions(+), 315 deletions(-)
delete mode 100644 doc/.tx/config
hooks/post-receive
