[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-224-gbcfb0a86c
git at osgeo.org
git at osgeo.org
Thu Jan 13 12:14:12 PST 2022
the project "PostGIS".
via bcfb0a86cbac42e73235c88a8d6e37f96739ddfd (commit)
from 3b8e21e586aa649ee8c9c79814755b1d6eece148 (commit)
revisions in full, below.
commit bcfb0a86cbac42e73235c88a8d6e37f96739ddfd
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 13 20:02:28 2022 +0000
Translated using Weblate (Italian)
Currently translated at 100.0% (20 of 20 strings)
Translation: postgis/reporting.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/reportingxml/it/
diff --git a/doc/po/it_IT/reporting.xml.po b/doc/po/it_IT/reporting.xml.po
index 748b31085..fa4741e22 100644
--- a/doc/po/it_IT/reporting.xml.po
+++ b/doc/po/it_IT/reporting.xml.po
@@ -9,15 +9,16 @@ msgstr ""
"Project-Id-Version: PostGIS\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2021-09-11 01:55+0000\n"
-"PO-Revision-Date: 2014-10-20 15:20+0000\n"
+"PO-Revision-Date: 2022-01-13 20:14+0000\n"
"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
-"Language-Team: Italian (Italy) (http://www.transifex.com/projects/p/postgis/"
-"language/it_IT/)\n"
+"Language-Team: Italian <https://weblate.osgeo.org/projects/postgis/"
+"reportingxml/it/>\n"
"Language: it_IT\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=n != 1;\n"
+"X-Generator: Weblate 4.10.1\n"
#. Tag: title
#: reporting.xml:3
@@ -33,7 +34,7 @@ msgstr "Segnalare Bug del Software"
#. Tag: para
#: reporting.xml:8
-#, fuzzy, no-c-format
+#, no-c-format
msgid ""
"Reporting bugs effectively is a fundamental way to help PostGIS development. "
"The most effective bug report is that enabling PostGIS developers to "
@@ -47,12 +48,12 @@ msgstr ""
"sviluppatori PostGIS di replicarlo, quindi idealmente contiene uno script "
"che lo rende evidente e un elenco di informazioni sull'ambiente in cui si "
"verifica. Le informazioni indispensabili possono essere estratte eseguendo "
-"<code>SELECT postgis_full_version()</code> [per postgis] and <code>SELECT "
+"<code>SELECT postgis_full_version()</code> [per PostGIS] and <code>SELECT "
"version()</code> [per postgresql]."
#. Tag: para
#: reporting.xml:16
+#, no-c-format
msgid ""
"If you aren't using the latest release, it's worth taking a look at its "
"<ulink url=\"https://git.osgeo.org/gitea/postgis/postgis/raw/branch/master/"
@@ -60,8 +61,9 @@ msgid ""
"been fixed."
msgstr ""
"Se non si sta usando l'ultima release, vale la pena leggerne il <ulink url="
-"\"http://svn.osgeo.org/postgis/trunk/NEWS\">release changelog</ulink>, per "
-"scoprire se il bug in questione è già stato risolto."
+"\"https://git.osgeo.org/gitea/postgis/postgis/raw/branch/master/NEWS\""
+">release changelog</ulink>, per scoprire se il bug in questione è già stato "
+"risolto."
#. Tag: para
#: reporting.xml:21
@@ -87,7 +89,7 @@ msgid ""
"chiark.greenend.org.uk/~sgtatham/bugs.html\">How to Report Bugs Effectively</"
"ulink> before filing a new report."
msgstr ""
-"Consigliamo la lettura del paper di Simon Tatham su <ulink url=\"http://www."
+"Consigliamo la lettura del paper di Simon Tatham su <ulink url=\"http://www."
"ulink> (Come riportare bug in modo efficiente) prima di compilare un nuovo "
"bug report."
@@ -145,22 +147,21 @@ msgstr ""
#. Tag: para
#: reporting.xml:54
+#, no-c-format
msgid "Clone the PostGIS' git repository. On Unix, type:"
-msgstr ""
-"Eseguire il checkout del trunk di PostGIS da Subversion. In Unix, digitare:"
+msgstr "Ottieni un clone del repository git di PostGIS. In Unix, digita:"
#. Tag: command
#: reporting.xml:57
#, no-c-format
msgid "git clone https://git.osgeo.org/gitea/postgis/postgis.git"
-msgstr ""
+msgstr "git clone https://git.osgeo.org/gitea/postgis/postgis.git"
#. Tag: para
#: reporting.xml:60
+#, no-c-format
msgid "This will be stored in the directory postgis"
-msgstr "I file saranno salvati nella cartella ./trunk"
+msgstr "I file saranno salvati nella cartella postgis"
#. Tag: para
#: reporting.xml:64
@@ -174,9 +175,9 @@ msgstr ""
#. Tag: command
#: reporting.xml:67
+#, no-c-format
msgid "vim doc/postgis.xml"
-msgstr "vim trunk/doc/postgis.xml"
+msgstr "vim doc/postgis.xml"
#. Tag: para
#: reporting.xml:69
@@ -202,9 +203,9 @@ msgstr ""
#. Tag: command
#: reporting.xml:78
+#, no-c-format
msgid "git diff doc/postgis.xml > doc.patch"
-msgstr "svn diff trunk/doc/postgis.xml > doc.patch"
+msgstr "git diff doc/postgis.xml > doc.patch"
#. Tag: para
#: reporting.xml:83
Summary of changes:
doc/po/it_IT/reporting.xml.po | 41 +++++++++++++++++++++--------------------
1 file changed, 21 insertions(+), 20 deletions(-)
hooks/post-receive
