[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-229-gdd794022a
git at osgeo.org
git at osgeo.org
Thu Jan 13 16:03:48 PST 2022
the project "PostGIS".
via dd794022afa8924d447702390c6e49c1f52284ca (commit)
from 8c741465d1f8468fbea25110424dfcef61552bb1 (commit)
revisions in full, below.
commit dd794022afa8924d447702390c6e49c1f52284ca
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Jan 14 01:03:20 2022 +0100
Cleanup translation (drop old commented-out translations)
diff --git a/doc/po/it_IT/installation.xml.po b/doc/po/it_IT/installation.xml.po
index 5c05c4f25..733f59405 100644
--- a/doc/po/it_IT/installation.xml.po
+++ b/doc/po/it_IT/installation.xml.po
@@ -2,9 +2,6 @@
# Translators:
# pibinko <pibinko at gmail.com>, 2013
-# pibinko <pibinko at gmail.com>, 2013
-# Sandro Santilli <strk.io>, 2015
-# Sandro Santilli <strk at kbt.io>, 2015
msgid ""
msgstr ""
@@ -1310,6 +1307,8 @@ msgid ""
"If successful, make check will produce the output of almost 500 tests. The "
"results will look similar to the following (numerous lines omitted below):"
msgstr ""
+"Se il test è positivo, l'uscita conterrà il risultato di molti test "
+"la schermata dovrebbe essere simile alla seguente (molte linee sono omesse):"
#. Tag: programlisting
#: installation.xml:706
@@ -1768,6 +1767,8 @@ msgid ""
"If you are using PostgreSQL 9.1+ and PostGIS 2.1+, you can take advantage of "
"the new extension model for installing tiger geocoder. To do so:"
msgstr ""
+"Se state utilizzando PostgreSQL 9.1+ e PostGIS 2.1+, potete utilizzare "
+"potete usare il sistema di estensioni. Per farlo:"
#. Tag: para
#: installation.xml:820
@@ -2670,560 +2671,3 @@ msgstr ""
"<varname>POSTGIS_PGSQL_VERSION</varname>, <varname>POSTGIS_PROJ_VERSION</"
"varname> e <varname>POSTGIS_GEOS_VERSION</varname> siano assegnate "
"correttamente."
-#, no-c-format
-#~ msgid ""
-#~ "If successful, the output of the test should be similar to the following:"
-#~ msgstr ""
-#~ "Se il test è positivo, l'uscita dovrebbe essere simile alla seguente:"
-#~ msgid "Loader/Dumper"
-#~ msgstr "Loader/Dumper"
-#~ msgid ""
-#~ "The data loader and dumper are built and installed automatically as part "
-#~ "of the PostGIS build. To build and install them manually:"
-#~ msgstr ""
-#~ "Il loader e il dumper dei dati sono compilati e installati "
-#~ "automaticamente con PostGIS. Per compilarli e installarli manualmente:"
-#~ msgid ""
-#~ "# cd postgis-&last_release_version;/loader\n"
-#~ "# make\n"
-#~ "# make install"
-#~ msgstr ""
-#~ "# make\n"
-#~ msgid ""
-#~ "The loader is called <filename>shp2pgsql</filename> and converts ESRI "
-#~ "Shape files into SQL suitable for loading in PostGIS/PostgreSQL. The "
-#~ "dumper is called <filename>pgsql2shp</filename> and converts PostGIS "
-#~ "tables (or queries) into ESRI Shape files. For more verbose "
-#~ "documentation, see the online help, and the manual pages."
-#~ msgstr ""
-#~ "Il loader si chiama <filename>shp2pgsql</filename> e converte gli "
-#~ "Shapefile ESRI in formato SQL adatto al caricamento in PostGIS/"
-#~ "PostgreSQL. Il dumper si chiama <filename>pgsql2shp</filename> e converte "
-#~ "le tabelle (o le query) di PostGIS in formato Shapefile ESRI. Per una "
-#~ "documentazione più estesa, si rimanda alla guida in linea e alle pagine "
-#~ "del manuale."
-#~ msgid ""
-#~ "Please refer to <xref linkend=\"make_install_postgis_extensions\"/> for "
-#~ "more details about querying installed/available extensions and upgrading "
-#~ "extensions, or switching from a non-extension install to an extension "
-#~ "install."
-#~ msgstr ""
-#~ "Vedi <xref linkend=\"make_install_postgis_extensions\"/> per maggiori "
-#~ "informazioni riguardo l'ispezione delle estensioni installate/disponibili "
-#~ "e il loro aggiornamento, o per passare da un'installazione semplice ad "
-#~ "una per estensioni."
-#, fuzzy
-#~ msgid "Configuring raster"
-#~ msgstr "Configurazione"
-#, fuzzy
-#~ msgid ""
-#~ "svn checkout https://svn.osgeo.org/postgis/trunk/ postgis-"
-#~ "&last_release_version;"
-#~ msgstr ""
-#~ "svn checkout http://svn.osgeo.org/postgis/trunk/ postgis-"
-#~ msgid "Creating a spatial database using EXTENSIONS"
-#~ msgstr "Creare un database spaziale con le ESTENSIONI"
-#~ msgid ""
-#~ "If you are using PostgreSQL 9.1+ and have compiled and installed the "
-#~ "extensions/ postgis modules, you can create a spatial database the new "
-#~ "way."
-#~ msgstr ""
-#~ "Se state utilizzando PostgreSQL9.1 o superiore e avete compilato e "
-#~ "installato i moduli delle estensioni postgis, potete creare un database "
-#~ "spaziale col nuovo sistema."
-#~ msgid "createdb [yourdatabase]"
-#~ msgstr "createdb [il_tuo_database]"
-#~ msgid "psql -d [yourdatabase] -c \"CREATE EXTENSION postgis;\""
-#~ msgstr "psql -d [il_tuo_database] -c \"CREATE EXTENSION postgis;\""
-#, fuzzy
-#~ msgid ""
-#~ "Raster is packaged as a separate extension and installable with command:"
-#~ msgstr ""
-#~ "La topologia è compresa in un'estensione separata e può essere installata "
-#~ "con il comando:"
-#, fuzzy
-#~ msgid "psql -d [yourdatabase] -c \"CREATE EXTENSION postgis_raster;\""
-#~ msgid ""
-#~ "Topology is packaged as a separate extension and installable with command:"
-#~ msgstr ""
-#~ msgid "psql -d [yourdatabase] -c \"CREATE EXTENSION postgis_topology;\""
-#~ msgstr "psql -d [il_tuo_database] -c \"CREATE EXTENSION postgis_topology;\""
-#~ msgid ""
-#~ "If you plan to restore an old backup from prior versions in this new db, "
-#~ "run:"
-#~ msgstr ""
-#~ "Se prevedete di ripristinare un vecchio backup, da una versione "
-#~ "precedente, nel nuovo database, eseguite:"
-#~ msgid "psql -d [yourdatabase] -f legacy.sql"
-#~ msgstr "psql -d [il_tuo_database] -f legacy.sql"
-#~ msgid ""
-#~ "You can later run <filename>uninstall_legacy.sql</filename> to get rid of "
-#~ "the deprecated functions after you are done with restoring and cleanup."
-#~ msgstr ""
-#~ "Potete successivamente eseguire <filename>uninstall_legacy.sql</filename> "
-#~ "per sbarazzarvi delle funzioni obsolete, dopo che avete concluso il "
-#~ "ripristino e la pulizia del database."
-#~ msgid ""
-#~ "The first step in creating a PostGIS database is to create a simple "
-#~ "PostgreSQL database."
-#~ msgstr ""
-#~ "Il primo passo per creare un database PostGIS consiste nel creare un "
-#~ "semplice database PostgreSQL."
-#~ msgid ""
-#~ "Many of the PostGIS functions are written in the PL/pgSQL procedural "
-#~ "language. As such, the next step to create a PostGIS database is to "
-#~ "enable the PL/pgSQL language in your new database. This is accomplish by "
-#~ "the command below command. For PostgreSQL 8.4+, this is generally already "
-#~ "installed"
-#~ msgstr ""
-#~ "Molte delle funzioni PostGIS sono scritte nel linguaggio procedurale PL/"
-#~ "pgSQL. Pertanto, il prossimo passo per creare un database PostGIS "
-#~ "consiste nell'abilitare il linguaggio PL/pgSQL nel vostro database. Per "
-#~ "questo deve essere eseguito il comando riportato sotto. Per PostgreSQL "
-#~ "8.4+, in genere PL/pgSQL è già installato"
-#~ msgid "createlang plpgsql [yourdatabase]"
-#~ msgstr "createlang plpgsql [il_tuo_database]"
-#~ msgid ""
-#~ "Now load the PostGIS object and function definitions into your database "
-#~ "by loading the <filename>postgis.sql</filename> definitions file (located "
-#~ "in <filename>[prefix]/share/contrib</filename> as specified during the "
-#~ "configuration step)."
-#~ msgstr ""
-#~ "Poi caricate le definizioni degli oggetti e delle funzioni PostGIS, "
-#~ "tramite il file di definizioni <filename>postgis.sql</filename> (ubicato "
-#~ "in <filename>[prefix]/share/contrib</filename> come specificato in fase "
-#~ "di configurazione)."
-#~ msgid "psql -d [yourdatabase] -f postgis.sql"
-#~ msgstr "psql -d [il_tuo_database] -f postgis.sql"
-#~ msgid ""
-#~ "For a complete set of EPSG coordinate system definition identifiers, you "
-#~ "can also load the <filename>spatial_ref_sys.sql</filename> definitions "
-#~ "file and populate the <varname>spatial_ref_sys</varname> table. This will "
-#~ "permit you to perform ST_Transform() operations on geometries."
-#~ msgstr ""
-#~ "Per un insieme completo dei sistemi di coordinate con gli identificatori "
-#~ "EPSG potete caricare il file di definizioni <filename>spatial_ref_sys."
-#~ "sql</filename> e caricare i valori nella tabella "
-#~ "<varname>spatial_ref_sys</varname>. Ciò vi consentirà di eseguire le "
-#~ "operazioni ST_Transform() sulle geometrie."
-#~ msgid "psql -d [yourdatabase] -f spatial_ref_sys.sql"
-#~ msgstr "psql -d [il_tuo_database] -f spatial_ref_sys.sql"
-#~ msgid ""
-#~ "If you wish to add comments to the PostGIS functions, the final step is "
-#~ "to load the <filename>postgis_comments.sql</filename> into your spatial "
-#~ "database. The comments can be viewed by simply typing <command>\\dd "
-#~ "[function_name]</command> from a <command>psql</command> terminal window."
-#~ msgstr ""
-#~ "Se volete aggiungere i commenti alle funzioni PostGIS, l'ultimo passo "
-#~ "consiste nel caricare <filename>postgis_comments.sql</filename> nel "
-#~ "vostro database spaziale. I commenti possono essere visti digitando "
-#~ "<command>\\dd [nome funzione]</command> da una finestra <command>psql</"
-#~ "command>."
-#~ msgid "psql -d [yourdatabase] -f postgis_comments.sql"
-#~ msgstr "psql -d [[il_tuo_database] -f postgis_comments.sql"
-#~ msgid "Install raster support"
-#~ msgstr "Installazione del supporto raster"
-#~ msgid "psql -d [yourdatabase] -f rtpostgis.sql"
-#~ msgstr "psql -d [il_tuo_database] -f rtpostgis.sql"
-#~ msgid ""
-#~ "Install raster support comments. This will provide quick help info for "
-#~ "each raster function using psql or PgAdmin or any other PostgreSQL tool "
-#~ "that can show function comments"
-#~ msgstr ""
-#~ "Installazione dei commenti per il supporto raster. Questo fornisce una "
-#~ "guida sintetica per ciascuna funzione raster utilizzando psql o PgAdmin o "
-#~ "qualsiasi altro strumento di PostgreSQL che possa mostrare i commenti "
-#~ "alle funzioni"
-#~ msgid "psql -d [yourdatabase] -f raster_comments.sql"
-#~ msgstr "psql -d [il_tuo_database] -f raster_comments.sql"
-#~ msgid "Install topology support"
-#~ msgstr "Installazione del supporto per la topologia"
-#~ msgid "psql -d [yourdatabase] -f topology/topology.sql"
-#~ msgstr "psql -d [il_tuo_database] -f topology/topology.sql"
-#~ msgid ""
-#~ "Install topology support comments. This will provide quick help info for "
-#~ "each topology function / type using psql or PgAdmin or any other "
-#~ "PostgreSQL tool that can show function comments"
-#~ msgstr ""
-#~ "Installa i commenti per il supporto topologico. Questa opzione fornisce "
-#~ "una guida rapida per ciascuna delle funzioni e i tipi topologici, tramite "
-#~ "psql o PgAdmin o qualsiasi altro strumento PostgreSQL con la capacità di "
-#~ "mostrare i commenti delle funzioni"
-#~ msgid "psql -d [yourdatabase] -f topology/topology_comments.sql"
-#~ msgstr "psql -d [il_tuo_database] -f topology/topology_comments.sql"
-#~ msgid ""
-#~ "There is an alternative <filename>legacy_minimal.sql</filename> you can "
-#~ "run instead which will install barebones needed to recover tables and "
-#~ "work with apps like MapServer and GeoServer. If you have views that use "
-#~ "things like distance / length etc, you'll need the full blown "
-#~ "<filename>legacy.sql</filename>"
-#~ msgstr ""
-#~ "E' inoltre disponibile un file alternativo (<filename>legacy_minimal.sql</"
-#~ "filename>) che potete eseguire per installare i componenti minimi "
-#~ "richiesti per ripristinare le tabelle e operare con applicazioni come "
-#~ "MapServer e GeoServer. Se avete delle viste che utilizzano elementi come "
-#~ "distanza, lunghezza, ecc, vi servirà il file completo <filename>legacy."
-#~ "sql</filename>"
-#~ msgid "Create a spatially-enabled database from a template"
-#~ msgstr ""
-#~ "Creare un database con funzionalità spaziali a partire da uno schema di "
-#~ "esempio"
-#~ msgid ""
-#~ "Some packaged distributions of PostGIS (in particular the Win32 "
-#~ "installers for PostGIS >= 1.1.5) load the PostGIS functions into a "
-#~ "template database called <varname>template_postgis</varname>. If the "
-#~ "<varname>template_postgis</varname> database exists in your PostgreSQL "
-#~ "installation then it is possible for users and/or applications to create "
-#~ "spatially-enabled databases using a single command. Note that in both "
-#~ "cases, the database user must have been granted the privilege to create "
-#~ "new databases."
-#~ msgstr ""
-#~ "Alcune distribuzioni pacchettizzate di PostGIS (in particolare i file di "
-#~ "installazione Win32 per PostGIS > 1.1.5) caricano le funzioni PostGIS in "
-#~ "un database di esempio denominato <varname>template_postgis</varname>. Se "
-#~ "il database <varname>template_postgis</varname> esiste nella vostra "
-#~ "installazione PostgreSQL, allora è possibile per utenti e applicazioni "
-#~ "creare database con funzioni spaziali utilizzando un singolo comando. Da "
-#~ "notare che in entrambi i casi all'utente del database deve essere "
-#~ "riconosciuto il ruolo di creare nuovi database."
-#~ msgid "From the shell:"
-#~ msgstr "Dalla riga di comando:"
-#~ msgid "# createdb -T template_postgis my_spatial_db"
-#~ msgstr "# createdb -T template_postgis my_spatial_db"
-#~ msgid "From SQL:"
-#~ msgstr "Da SQL:"
-#~ msgid "postgres=# CREATE DATABASE my_spatial_db TEMPLATE=template_postgis"
-#~ msgstr "postgres=# CREATE DATABASE my_spatial_db TEMPLATE=template_postgis"
-#~ msgid "Upgrading"
-#~ msgstr "Aggiornamento"
-#~ msgid ""
-#~ "Upgrading existing spatial databases can be tricky as it requires "
-#~ "replacement or introduction of new PostGIS object definitions."
-#~ msgstr ""
-#~ "L'aggiornamento di database spaziali preesistenti può essere complicato, "
-#~ "perché richiede la sostituzione o l'introduzione di nuove definizioni di "
-#~ "oggetti PostGIS."
-#~ msgid ""
-#~ "Unfortunately not all definitions can be easily replaced in a live "
-#~ "database, so sometimes your best bet is a dump/reload process."
-#~ msgstr ""
-#~ "Purtroppo non tutte le definizioni possono essere sostituite facilmente "
-#~ "in un database attivo, per cui in alcuni casi la cosa migliore è seguire "
-#~ "un processo di scaricamento e ricaricamento dei dati."
-#~ msgid ""
-#~ "If you installed your database using extensions, you'll need to upgrade "
-#~ "using the extension model as well. If you installed using the old sql "
-#~ "script way, then you should upgrade using the sql script way. Please "
-#~ "refer to the appropriate."
-#~ msgstr ""
-#~ "Se avete installato il database con le estensioni, dovrete eseguire anche "
-#~ "l'aggiornamento con il modello delle estensioni. Se avete invece eseguito "
-#~ "l'installazione con il vecchio sistema dello script SQL, anche "
-#~ "l'aggiornamento dovrà essere eseguito con lo script SQL. Fate riferimento "
-#~ "al paragrafo corrispondente."
-#~ msgid ""
-#~ "This section applies only to those who installed PostGIS not using "
-#~ "extensions. If you have extensions and try to upgrade with this approach "
-#~ "you'll get messages like:"
-#~ msgstr ""
-#~ "Questo paragrafo vale solo per coloro che hanno installato PostGIS senza "
-#~ "estensioni. Se avete le estensioni e provate a eseguire l'aggiornamento "
-#~ "con questo sistema, otterrete messaggi tipo:"
-#~ msgid "can't drop ... because postgis extension depends on it"
-#~ msgstr ""
-#~ "non posso eseguire il DROP, dato che c'è una dipendenza dell'estensione "
-#~ "PostGIS"
-#, fuzzy
-#~ msgid ""
-#~ "The same procedure applies to raster, topology and sfcgal extensions, "
-#~ "with upgrade files named <filename>rtpostgis_upgrade.sql</filename>, "
-#~ "<filename>topology_upgrade.sql</filename> and <filename>sfcgal_upgrade."
-#~ "sql</filename> respectively. If you need them:"
-#~ msgstr ""
-#~ "La stessa procedura si applica alle estensioni per i raster e per la "
-#~ "topologia, i cui file si chiamano rispettivamente "
-#~ "<filename>rtpostgis_upgrade*.sql</filename> e <filename>topology_upgrade*."
-#~ "sql</filename> respectively. Se vi servono:"
-#~ msgid ""
-#~ "The <xref linkend=\"PostGIS_Full_Version\"/> function should inform you "
-#~ "about the need to run this kind of upgrade using a \"procs need upgrade\" "
-#~ "message."
-#~ msgstr ""
-#~ "La funzione <xref linkend=\"PostGIS_Full_Version\"/> dovrebbe informarvi "
-#~ "della necessita di eseguire questo tipo di aggiornamento attraverso un "
-#~ "messaggio tipo \"procs need upgrade\"."
-#~ msgid ""
-#~ "If you originally installed PostGIS with extensions, then you need to "
-#~ "upgrade using extensions as well. Doing a minor upgrade with extensions, "
-#~ "is fairly painless."
-#~ msgstr ""
-#~ "Se inizialmente avete installato PostGIS con le estensioni, anche "
-#~ "l'aggiornamento dovrà essere eseguito con le estensioni. Eseguire un "
-#~ "aggiornamento di una versione minore con le estensioni è un'operazione "
-#~ "abbastanza tranquilla."
-#~ msgid ""
-#~ "ALTER EXTENSION postgis UPDATE TO \"&last_release_version;\";\n"
-#~ "ALTER EXTENSION postgis_topology UPDATE TO \"&last_release_version;\";"
-#~ msgstr ""
-#~ msgid "If you get an error notice something like:"
-#~ msgstr "Se ottenete un errore tipo:"
-#~ msgid "No migration path defined for ... to &last_release_version;"
-#~ msgstr "No migration path defined for ... to &last_release_version;"
-#~ msgid ""
-#~ "The dump/reload process is assisted by the postgis_restore.pl script "
-#~ "which takes care of skipping from the dump all definitions which belong "
-#~ "to PostGIS (including old ones), allowing you to restore your schemas and "
-#~ "data into a database with PostGIS installed without getting duplicate "
-#~ "symbol errors or bringing forward deprecated objects."
-#~ msgstr ""
-#~ "Il processo di scaricamento e ricaricamento dei dati viene assistito "
-#~ "dallo script postgis_restore.pl. Questo si fa carico di saltare nello "
-#~ "scaricamento tutte le definizioni che fanno parte di PostGIS (comprese "
-#~ "quelle obsolete), consentendo così di ripristinare gli schemi e i dati in "
-#~ "un database con PostGIS senza ottenere errori legati alla presenza di "
-#~ "simboli duplicati e senza portarsi dietro oggetti obsoleti. "
-#~ msgid ""
-#~ "Supplementary instructions for windows users are available at <ulink url="
-#~ "\"http://trac.osgeo.org/postgis/wiki/UsersWikiWinUpgrade\">Windows Hard "
-#~ "upgrade</ulink>."
-#~ msgstr ""
-#~ "Ulteriori istruzioni per gli utenti Windows sono disponibili alla pagina "
-#~ "<ulink url=\"http://trac.osgeo.org/postgis/wiki/UsersWikiWinUpgrade"
-#~ "\">Windows Hard upgrade</ulink>."
-#~ msgid "The Procedure is as follows:"
-#~ msgstr "La procedura è la seguente:"
-#~ msgid ""
-#~ "Create a \"custom-format\" dump of the database you want to upgrade "
-#~ "(let's call it <varname>olddb</varname>) include binary blobs (-b) and "
-#~ "verbose (-v) output. The user can be the owner of the db, need not be "
-#~ "postgres super account."
-#~ msgstr ""
-#~ "Create un dump \"con formato personalizzato\" del database da aggiornare "
-#~ "(che chiameremo <varname>olddb</varname>), includendo i blob binari (-b) "
-#~ "e con uscita dettagliata (-v). L'utente può essere il proprietario del "
-#~ "database, non serve avere privilegi da amministratore."
-#~ msgid ""
-#~ "pg_dump -h localhost -p 5432 -U postgres -Fc -b -v -f \"/somepath/olddb."
-#~ "backup\" olddb"
-#~ msgstr ""
-#~ msgid ""
-#~ "Do a fresh install of PostGIS in a new database -- we'll refer to this "
-#~ "database as <varname>newdb</varname>. Please refer to <xref linkend="
-#~ "\"create_new_db\"/> and <xref linkend=\"create_new_db_extensions\"/> for "
-#~ "instructions on how to do this."
-#~ msgstr ""
-#~ "Eseguire un'installazione da zero di PostGIS in un nuovo database -- "
-#~ "chiameremo questo database <varname>newdb</varname>. Vi rimandiamo a "
-#~ "<xref linkend=\"create_new_db\"/> e <xref linkend="
-#~ "\"create_new_db_extensions\"/> per le relative istruzioni."
-#~ msgid ""
-#~ "The spatial_ref_sys entries found in your dump will be restored, but they "
-#~ "will not override existing ones in spatial_ref_sys. This is to ensure "
-#~ "that fixes in the official set will be properly propagated to restored "
-#~ "databases. If for any reason you really want your own overrides of "
-#~ "standard entries just don't load the spatial_ref_sys.sql file when "
-#~ "creating the new db."
-#~ msgstr ""
-#~ "Le voci spatial_ref_sys presenti nel vostro dump saranno ripristinate, ma "
-#~ "non avranno la precedenza su quelle esistenti in spatial_ref_sys. Ciò è "
-#~ "per assicurarsi che l'elenco ufficiale venga correttamente trasmesso ai "
-#~ "database ripristinati. Se per una qualsiasi ragione volete davvero che le "
-#~ "vostre definizioni siano considerate al posto di quelle standard, potete "
-#~ "evitare di caricare spatial_ref_sys.sql nel momento in cui create il "
-#~ "nuovo database."
-#~ msgid ""
-#~ "If your database is really old or you know you've been using long "
-#~ "deprecated functions in your views and functions, you might need to load "
-#~ "<filename>legacy.sql</filename> for all your functions and views etc. to "
-#~ "properly come back. Only do this if _really_ needed. Consider upgrading "
-#~ "your views and functions before dumping instead, if possible. The "
-#~ "deprecated functions can be later removed by loading "
-#~ "<filename>uninstall_legacy.sql</filename>."
-#~ msgstr ""
-#~ "Se il vostro database è molto vecchio, o sapete che avete utilizzato "
-#~ "nelle vostre viste e nelle vostre funzioni delle funzioni obsolete, "
-#~ "potreste dover caricare il file <filename>legacy.sql</filename>. Eseguite "
-#~ "questa operazione solo se vi serve _veramente_. Considerate la "
-#~ "possibilità di aggiornare le vostre viste e le voste funzioni prima di "
-#~ "eseguire il dump, se possibile. Le funzioni obsolete possono poi essere "
-#~ "rimosse caricando il file <filename>uninstall_legacy.sql</filename>. "
-#~ msgid ""
-#~ "Restore your backup into your fresh <varname>newdb</varname> database "
-#~ "using postgis_restore.pl. Unexpected errors, if any, will be printed to "
-#~ "the standard error stream by psql. Keep a log of those."
-#~ msgstr ""
-#~ "Ripristinate il vostro backup nel nuovo database <varname>newdb</varname> "
-#~ "tramite postgis_restore.pl. Eventuali errori imprevisti, se presenti, "
-#~ "saranno trascritti da psql sull'uscita standard error. Tenete una traccia "
-#~ "di tali errori."
-#~ msgid ""
-#~ "perl utils/postgis_restore.pl \"/somepath/olddb.backup\" | psql -h "
-#~ "localhost -p 5432 -U postgres newdb 2> errors.txt"
-#~ msgstr ""
-#~ msgid "Errors may arise in the following cases:"
-#~ msgstr "Si potrebbero riscontrare errori nei casi seguenti:"
-#~ msgid ""
-#~ "Some of your views or functions make use of deprecated PostGIS objects. "
-#~ "In order to fix this you may try loading <filename>legacy.sql</filename> "
-#~ "script prior to restore or you'll have to restore to a version of PostGIS "
-#~ "which still contains those objects and try a migration again after "
-#~ "porting your code. If the <filename>legacy.sql</filename> way works for "
-#~ "you, don't forget to fix your code to stop using deprecated functions and "
-#~ "drop them loading <filename>uninstall_legacy.sql</filename>."
-#~ msgstr ""
-#~ "Alcune delle vostre viste o funzioni fanno uso di oggetti PostGIS "
-#~ "obsoleti. Per risolvere questo problema potete provare a caricare lo "
-#~ "script <filename>legacy.sql</filename> prima del ripristino, oppure "
-#~ "dovrete eseguire il ripristino in una versione di PostGIS che ancora "
-#~ "contenga quegli oggetti, e poi ritentare la migrazione dopo aver adattato "
-#~ "il codice alla nuova versione. Se il sistema <filename>legacy.sql</"
-#~ "filename> vi funziona, non dimenticate di sistemare il vostro codice, "
-#~ "eliminando i riferimenti alle funzioni obsolete, e poi disinstallate "
-#~ "tutti i vecchi riferimenti tramite <filename>uninstall_legacy.sql</"
-#~ "filename>."
-#~ msgid ""
-#~ "In order to fix this you should copy your custom SRS to a SRID with a "
-#~ "valid value (maybe in the 910000..910999 range), convert all your tables "
-#~ "to the new srid (see <xref linkend=\"UpdateGeometrySRID\"/>), delete the "
-#~ "invalid entry from spatial_ref_sys and re-construct the check(s) with:"
-#~ msgstr ""
-#~ "Per sistemare questo problema dovete copiare il vostro SRS personalizzato "
-#~ "in un SRID con un valore valido (nell'intervallo 910000..910999), "
-#~ "convertire tutte le tabelle nel nuovo SRID (vedi <xref linkend="
-#~ "\"UpdateGeometrySRID\"/>), cancellare la voce non valida da "
-#~ "spatial_ref_sys e ricostruire il controllo o in controlli con:"
-#~ msgid ""
-#~ "ALTER TABLE spatial_ref_sys ADD CONSTRAINT spatial_ref_sys_srid_check "
-#~ "check (srid > 0 AND srid < 999000 );"
-#~ msgstr ""
-#~ msgid "ALTER TABLE spatial_ref_sys ADD PRIMARY KEY(srid));"
-#~ msgstr "ALTER TABLE spatial_ref_sys ADD PRIMARY KEY(srid));"
-#~ msgid ""
-#~ "The raster support is currently optional, but installed by default. For "
-#~ "enabling using the PostgreSQL 9.1+ extensions model raster is required. "
-#~ "Using the extension enable process is preferred and more user-friendly. "
-#~ "To spatially enable your database:"
-#~ msgstr ""
-#~ "Il supporto per i raster è attualmente opzionale, ma installato di "
-#~ "default. Per abilitare l'uso di PostGIS come estensione (supportato da "
-#~ "PostgreSQL 9.1+) è necessario il supporto raster. Usare PostGIS come "
-#~ "estensione è il procedimento preferito e maggiormente user-friendly. Per "
-#~ "abilitare spazialmente il tuo database:"
-#~ msgid ""
-#~ "The rest of this chapter goes into detail each of the above installation "
-#~ "steps."
-#~ msgstr ""
-#~ "La restante parte di questo capitolo entra nel dettaglio di ciascuno dei "
-#~ "passi di installazione riportati soprta."
-#~ msgid ""
-#~ "Compile with raster support. This will build rtpostgis-"
-#~ "&last_release_version; library and rtpostgis.sql file. This may not be "
-#~ "required in final release as plan is to build in raster support by "
-#~ "default."
-#~ msgstr ""
-#~ "Compilare con supporto raster. Questo compilerà la libreria rtpostgis-"
-#~ "&last_release_version; e il file rtpostgis.sql. Potrebbe non essere "
-#~ "necessario nella release finale, dato che si prevede di avere il supporto "
-#~ "raster come default."
-#~ msgid ""
-#~ "If you installed postgis without raster support, you'll need to install "
-#~ "raster support first (using the full <filename>rtpostgis.sql</filename>"
-#~ msgstr ""
-#~ "Se avete installato PostGIS senza supporto raster, dovrete prima "
-#~ "installare il supporto raster (utilizzando tutto il file "
-#~ "<filename>rtpostgis.sql</filename>"
-#~ msgid ""
-#~ "Then you can run the below commands to package the functions in their "
-#~ "respective extension."
-#~ msgstr ""
-#~ "Poi potete eseguire i comandi seguenti per creare i pacchetti di funzioni "
-#~ "nelle estensioni corrispondenti."
Summary of changes:
doc/po/it_IT/installation.xml.po | 564 +--------------------------------------
1 file changed, 4 insertions(+), 560 deletions(-)
hooks/post-receive
