[postgis-tickets] [PostGIS] #5050: TopoGeo_AddPolygon() make postgres instance crash
trac at osgeo.org
Thu Jan 13 23:59:47 PST 2022
Reporter: wimned | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.5
Component: topology | Version: 3.1.x
Keywords: |
Adding a polygon results the postgres cluster to be crashed.
Raising an exception would be expected, not a crash.
Error message:
NOTICE: Corrupted topology: face 2 could not be constructed only from
edges knowing about it (like edge 24).
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
connection to server was lost
I attached a short script building op a topology with edges. Two of the
edges 'lay very close' to each other. Adding a polygon, with ring also
partly overlapping these edges, results in the crash
I attached the polygon and edge data in geojson files.
Version info:
PostgreSQL 12.9 (Ubuntu 12.9-2.pgdg20.04+1) on x86_64-pc-linux-gnu,
compiled by gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, 64-bit
(1 row)
postgis_version
3.1 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
(1 row)
Could be problems are already solved in newer versions, this input could
be added to the regression tests.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5050>
