[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-256-g03356dc74
Sat Jan 15 12:27:32 PST 2022
the project "PostGIS".
       via  03356dc743b1b70fd4f3a2926bc7382cbffc14c7 (commit)
       via  c5e7d4f27623e307cb528eac654253869ac47860 (commit)
      from  3a3a84df865fc111ba35b2e123ae8abde0398f41 (commit)
revisions in full, below.
commit 03356dc743b1b70fd4f3a2926bc7382cbffc14c7
Merge: c5e7d4f27 3a3a84df8
Author: Regina Obe <lr at pcorp.us>
Date:   Sat Jan 15 15:27:19 2022 -0500
    Merge branch 'master' of git.osgeo.org:postgis/postgis
commit c5e7d4f27623e307cb528eac654253869ac47860
Date:   Sat Jan 15 15:26:56 2022 -0500
    Reconcile ja reporting with latests changes in pot
diff --git a/doc/po/ja/reporting.xml.po b/doc/po/ja/reporting.xml.po
index f9996dbc1..1e0954cca 100644
--- a/doc/po/ja/reporting.xml.po
+++ b/doc/po/ja/reporting.xml.po
@@ -4,8 +4,8 @@
 msgid ""
 msgstr ""
 "Project-Id-Version: PostGIS\n"
-"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2021-09-11 01:55+0000\n"
+"Report-Msgid-Bugs-To: http://bugs.kde.org\n"
+"POT-Creation-Date: 2022-01-15 20:24+0000\n"
 "PO-Revision-Date: 2022-01-14 03:14+0000\n"
 "Last-Translator: TERAMOTO Ikuhiro <yellow at affrc.go.jp>\n"
 "Language-Team: Japanese (http://www.transifex.com/postgis/postgis/language/"
@@ -129,9 +129,9 @@ msgstr ""
 #: reporting.xml:47
 #, fuzzy, no-c-format
 msgid ""
-"If your changes are more extensive, a Subversion patch is definitely "
-"preferred. This is a four step process on Unix (assuming you already have "
-"<ulink url=\"http://subversion.apache.org/\">Subversion</ulink> installed):"
+"If your changes are more extensive, a patch is definitely preferred. This is "
+"a four step process on Unix (assuming you already have <ulink url=\"https://"
+"git-scm.com/\">git</ulink> installed):"
 msgstr ""
 "変更が大きい場合は、パッチが確実に好まれます。Unix上で次の4ステップの処理を行"
 "います (既に<ulink url=\"https://git-scm.com/\">git</ulink>をインストールして"
Summary of changes:
 doc/po/ja/reporting.xml.po | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
hooks/post-receive
