[postgis-tickets] [PostGIS] #5054: make check fails to fully check upgrades
trac at osgeo.org
Sun Jan 16 12:46:30 PST 2022
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: build/upgrade/install | Version: 3.2.x
Keywords: |
When `make check` is run without setting RUNTESTFLAGS=--upgrade, a rule
will additionally also execute an upgrade test but such test will NOT
include before/after upgrade hooks, which in turn fails to catch some
upgrade errors.
Refer to
https://trac.osgeo.org/postgis/ticket/5046?cnum_edit=13#comment:13 for an
example of this false negative testrun currently performed by github
actions.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5054>
