[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-257-g4c3c8e378
git at osgeo.org
git at osgeo.org
Sun Jan 16 12:45:14 PST 2022
the project "PostGIS".
via 4c3c8e37839127b67dc3f0cf08f67cddc7441d89 (commit)
from 03356dc743b1b70fd4f3a2926bc7382cbffc14c7 (commit)
revisions in full, below.
commit 4c3c8e37839127b67dc3f0cf08f67cddc7441d89
Author: Regina Obe <regina at arrival3d.com>
Date: Sat Jan 15 20:33:26 2022 +0000
Translated using Weblate (Japanese)
Currently translated at 100.0% (20 of 20 strings)
Translation: postgis/reporting.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/reportingxml/ja/
diff --git a/doc/po/ja/reporting.xml.po b/doc/po/ja/reporting.xml.po
index 1e0954cca..3ac5b01ee 100644
--- a/doc/po/ja/reporting.xml.po
+++ b/doc/po/ja/reporting.xml.po
@@ -6,15 +6,16 @@ msgstr ""
"Project-Id-Version: PostGIS\n"
"Report-Msgid-Bugs-To: http://bugs.kde.org\n"
"POT-Creation-Date: 2022-01-15 20:24+0000\n"
-"PO-Revision-Date: 2022-01-14 03:14+0000\n"
-"Last-Translator: TERAMOTO Ikuhiro <yellow at affrc.go.jp>\n"
-"Language-Team: Japanese (http://www.transifex.com/postgis/postgis/language/"
-"ja/)\n"
+"PO-Revision-Date: 2022-01-16 20:45+0000\n"
+"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"reportingxml/ja/>\n"
"Language: ja\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"Plural-Forms: nplurals=1; plural=0;\n"
+"X-Generator: Weblate 4.10.1\n"
#. Tag: title
#: reporting.xml:3
@@ -127,15 +128,14 @@ msgstr ""
#. Tag: para
#: reporting.xml:47
-#, fuzzy, no-c-format
+#, no-c-format
msgid ""
"If your changes are more extensive, a patch is definitely preferred. This is "
"a four step process on Unix (assuming you already have <ulink url=\"https://"
"git-scm.com/\">git</ulink> installed):"
msgstr ""
-"変更が大きい場合は、パッチが確実に好まれます。Unix上で次の4ステップの処理を行"
-"います (既に<ulink url=\"https://git-scm.com/\">git</ulink>をインストールして"
-"いると仮定します)。"
+"変更が大きい場合は、パッチが確実に好まれます。Unix上で次の4ステップの処理を行います (既に<ulink url=\"https://git-scm."
+"com/\">git</ulink>をインストールしていると仮定します)。"
#. Tag: para
#: reporting.xml:54
Summary of changes:
doc/po/ja/reporting.xml.po | 16 ++++++++--------
1 file changed, 8 insertions(+), 8 deletions(-)
hooks/post-receive
