[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.0-16-gab601a090
git at osgeo.org
git at osgeo.org
Mon Jan 17 06:12:38 PST 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
via ab601a09099e12f2763e0f27a86134f9d644fdb2 (commit)
via 82e080b2a0fe7814bdcdccfde0416f663f63ad1a (commit)
via 5082e5f40d842b1a6d966b1dbdcd99c8fbcd4155 (commit)
from 5e567ee145cec652ad1c1276cb9a2bf7898447b6 (commit)
revisions in full, below.
commit ab601a09099e12f2763e0f27a86134f9d644fdb2
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Jan 13 23:57:36 2022 +0100
Rewrite _postgis_drop_if_needed to avoid expanding DEFAULT values
This prevents the function to fail when geometry canonical output
function is non-functional (maybe due to lack of library on system).
References #5046 in 3.2 branch (3.2.1dev)
Includes test ugprades in absence of old library
Includes NEWS item
diff --git a/NEWS b/NEWS
index 75332c299..a11f163fa 100644
--- a/NEWS
+++ b/NEWS
@@ -4,6 +4,7 @@ YYYY/MM/DD
* Bug Fixes *
- #5033, #5035, allow upgrades in presence of views using deprecated
functions (Sandro Santilli)
+ - #5046, Fix upgrades in absence of old library (Sandro Santilli)
PostGIS 3.2.0 (Olivier Courtin Edition)
2021/12/17
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index ea84c524f..437476be0 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -37,34 +37,29 @@ CREATE OR REPLACE FUNCTION _postgis_drop_function_if_needed(
function_name text,
function_arguments text) RETURNS void AS $$
DECLARE
- frec RECORD;
sql_drop text;
+ postgis_namespace OID;
+ matching_function REGPROCEDURE;
BEGIN
- FOR frec IN
- SELECT p.oid as oid,
- n.nspname as schema,
- n.oid as schema_oid,
- p.proname as name,
- pg_catalog.pg_get_function_arguments(p.oid) as arguments,
- pg_catalog.pg_get_function_identity_arguments(p.oid) as identity_arguments
- FROM pg_catalog.pg_proc p
- LEFT JOIN pg_catalog.pg_namespace n ON n.oid = p.pronamespace
- WHERE
- n.oid = (
- SELECT n.oid
- FROM pg_proc p
- JOIN pg_namespace n ON p.pronamespace = n.oid
- WHERE proname = 'postgis_full_version'
- ) AND
- LOWER(p.proname) = LOWER(function_name) AND
- LOWER(pg_catalog.pg_get_function_arguments(p.oid)) ~ LOWER(function_arguments) AND
- pg_catalog.pg_function_is_visible(p.oid)
- ORDER BY 1, 2, 4
- LOOP
- sql_drop := 'DROP FUNCTION ' || quote_ident(frec.schema) || '.' || quote_ident(frec.name) || ' ( ' || frec.identity_arguments || ' ) ';
- RAISE DEBUG 'Name (%): %', frec.oid, frec.name;
- RAISE DEBUG 'Arguments: %', frec.arguments;
- RAISE DEBUG 'Identity arguments: %', frec.identity_arguments;
+ -- Fetch install namespace for PostGIS
+ SELECT n.oid
+ FROM pg_catalog.pg_proc p
+ JOIN pg_catalog.pg_namespace n ON p.pronamespace = n.oid
+ WHERE proname = 'postgis_full_version'
+ INTO postgis_namespace;
+ -- Find a function matching the given signature
+ SELECT oid
+ WHERE pronamespace = postgis_namespace
+ AND LOWER(p.proname) = LOWER(function_name)
+ AND pg_catalog.pg_function_is_visible(p.oid)
+ AND LOWER(pg_catalog.pg_get_function_identity_arguments(p.oid)) ~ LOWER(function_arguments)
+ INTO matching_function;
+ IF matching_function IS NOT NULL THEN
+ sql_drop := 'DROP FUNCTION ' || matching_function;
RAISE DEBUG 'SQL query: %', sql_drop;
BEGIN
EXECUTE sql_drop;
@@ -72,7 +67,8 @@ BEGIN
WHEN OTHERS THEN
RAISE EXCEPTION 'Could not drop function %. You might need to drop dependant objects. Postgres error: %', function_name, SQLERRM;
END;
- END LOOP;
+ END IF;
END;
$$ LANGUAGE plpgsql;
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index 5f4678446..7185b56bc 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -74,3 +74,8 @@ SELECT
ST_DWithin(g1::text, g1::text, 1) as text_dwithin,
ST_DWithin(g2, g2, 1) as geography_dwithin
FROM upgrade_test;
+-- Break probin of all postgis functions, as we expect
+-- the upgrade procedure to replace them all
+UPDATE pg_proc SET probin = probin || '-uninstalled'
+WHERE probin like '%postgis%';
commit 82e080b2a0fe7814bdcdccfde0416f663f63ad1a
Date: Mon Jan 17 15:06:59 2022 +0100
Various improvements in run_test.pl (matches master branch)
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 5322e5e95..9810a81d7 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1538,62 +1538,29 @@ sub upgrade_spatial
print "Upgrading PostGIS in '${DB}' \n" ;
- my $script = `ls ${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading core\n";
- load_sql_file($script);
- else
- die "$script not found\n";
+ my $script = "${STAGED_SCRIPTS_DIR}/postgis_upgrade.sql";
+ print "Upgrading core\n";
+ die unless load_sql_file($script, 1);
if ( $OPT_WITH_TOPO )
- my $script = `ls ${STAGED_SCRIPTS_DIR}/topology_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading topology\n";
- else
+ $script = "${STAGED_SCRIPTS_DIR}/topology_upgrade.sql";
+ print "Upgrading topology\n";
if ( $OPT_WITH_RASTER )
- my $script = `ls ${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading raster\n";
- else
+ $script = "${STAGED_SCRIPTS_DIR}/rtpostgis_upgrade.sql";
+ print "Upgrading raster\n";
if ( $OPT_WITH_SFCGAL )
- my $script = `ls ${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql`;
- chomp($script);
- if ( -e $script )
- print "Upgrading sfcgal\n";
- else
+ $script = "${STAGED_SCRIPTS_DIR}/sfcgal_upgrade.sql";
+ print "Upgrading sfcgal\n";
return 1;
commit 5082e5f40d842b1a6d966b1dbdcd99c8fbcd4155
Date: Sun Jan 16 21:52:25 2022 +0100
Include internal RUNTESTFLAGS when testing upgrades
Fixes #5054 in 3.2 branch (3.2.1dev)
diff --git a/regress/runtest.mk b/regress/runtest.mk
index 5df1a3968..4d8edc8b3 100644
--- a/regress/runtest.mk
+++ b/regress/runtest.mk
@@ -19,6 +19,7 @@ check-regress:
$(PERL) $(topsrcdir)/regress/run_test.pl \
--upgrade \
$(RUNTESTFLAGS) \
+ $(RUNTESTFLAGS_INTERNAL) \
$(TESTS); \
fi
Summary of changes:
NEWS | 1 +
postgis/postgis_before_upgrade.sql | 50 ++++++++++++++----------------
regress/hooks/hook-before-upgrade.sql | 5 +++
regress/run_test.pl | 57 ++++++++---------------------------
regress/runtest.mk | 1 +
5 files changed, 42 insertions(+), 72 deletions(-)
hooks/post-receive
