[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.0-17-g311850119
git at osgeo.org
git at osgeo.org
Mon Jan 17 06:23:56 PST 2022
the project "PostGIS".
The branch, stable-3.2 has been updated
via 3118501190d25a3f48e70f21937037f45a95e5e9 (commit)
from ab601a09099e12f2763e0f27a86134f9d644fdb2 (commit)
revisions in full, below.
commit 3118501190d25a3f48e70f21937037f45a95e5e9
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Jan 14 11:39:43 2022 +0100
Run topology and raster --before-upgrade hooks *before* the core ones
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index db11bdd3e..50d0c11ea 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -12,9 +12,10 @@
override RUNTESTFLAGS := $(RUNTESTFLAGS) --raster
-RUNTESTFLAGS_INTERNAL += \
+override RUNTESTFLAGS_INTERNAL := \
--before-upgrade-script $(topsrcdir)/raster/test/regress/hooks/hook-before-upgrade-raster.sql \
- --after-upgrade-script $(topsrcdir)/raster/test/regress/hooks/hook-after-upgrade-raster.sql
+ $(RUNTESTFLAGS_INTERNAL) \
+ --after-upgrade-script $(topsrcdir)/raster/test/regress/hooks/hook-after-upgrade-raster.sql
RASTER_TEST_FIRST = \
$(topsrcdir)/raster/test/regress/check_gdal \
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 63cfaf20c..8255316c4 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -12,9 +12,10 @@
override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
--before-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-before-upgrade-topology.sql \
- --after-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-after-upgrade-topology.sql
+ --after-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-after-upgrade-topology.sql
TESTS += \
$(topsrcdir)/topology/test/regress/addedge.sql \
Summary of changes:
raster/test/regress/tests.mk | 5 +++--
topology/test/tests.mk | 5 +++--
2 files changed, 6 insertions(+), 4 deletions(-)
hooks/post-receive
