[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-266-g5149a7d64
git at osgeo.org
git at osgeo.org
Mon Jan 17 09:45:47 PST 2022
the project "PostGIS".
via 5149a7d647f6c69bb621dcb5f2027385c8db9c0e (commit)
from 5b4ab2cfc521b2d9955d17e46a02c7ccaef778b6 (commit)
revisions in full, below.
commit 5149a7d647f6c69bb621dcb5f2027385c8db9c0e
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Mon Jan 17 05:42:14 2022 +0000
Translated using Weblate (Japanese)
Currently translated at 19.5% (17 of 87 strings)
Translation: postgis/administration.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/administrationxml/ja/
diff --git a/doc/po/ja/administration.xml.po b/doc/po/ja/administration.xml.po
index 2ee99127b..94e3e18db 100644
--- a/doc/po/ja/administration.xml.po
+++ b/doc/po/ja/administration.xml.po
@@ -1,37 +1,39 @@
# SOME DESCRIPTIVE TITLE.
# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
-#, fuzzy
msgid ""
msgstr ""
"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2021-09-11 01:55+0000\n"
-"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
-"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
-"Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
-"Language: \n"
+"PO-Revision-Date: 2022-01-17 17:45+0000\n"
+"Last-Translator: Teramoto Ikuhiro <yellow at affrc.go.jp>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"administrationxml/ja/>\n"
+"Language: ja\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
+"Plural-Forms: nplurals=1; plural=0;\n"
+"X-Generator: Weblate 4.10.1\n"
#. Tag: title
#: administration.xml:3
#, no-c-format
msgid "PostGIS Administration"
-msgstr ""
+msgstr "PostGIS管理"
#. Tag: chapter
-#, no-c-format
+#, fuzzy, no-c-format
msgid "&database_tuning;"
-msgstr ""
+msgstr "&database_tuning;"
#. Tag: title
#: administration.xml:9
#, no-c-format
msgid "Configuring raster support"
-msgstr ""
+msgstr "ラスタ機能の設定"
#. Tag: para
#: administration.xml:11
@@ -39,7 +41,7 @@ msgstr ""
msgid ""
"If you enabled raster support you may want to read below how to properly "
"configure it."
-msgstr ""
+msgstr "ラスタ機能を有効にしたら、下に示す確実な設定方法を読んだ方がいいです。"
#. Tag: para
#: administration.xml:16
@@ -52,24 +54,28 @@ msgid ""
"For PostGIS 2.2, you can use the more cross-platform approach of setting the "
"corresponding <xref linkend=\"PostGIS_GUC\"/>."
msgstr ""
+"PostGIS 2.1.3以降では、データベース外ラスタと全てのラスタドライバは、デフォルトでは無効になっています。これらを有効にするには、サーバ上で、"
+"環境変数 <varname>POSTGIS_GDAL_ENABLED_DRIVERS</varname>と<varname>POSTGIS_ENABLE_"
+"OUTDB_RASTERS</varname>を設定します。PostGIS 2.2では、<xref linkend=\"PostGIS_GUC\""
+"/>に従って設定する、クロスプラットフォームな手法があります。"
#. Tag: para
#: administration.xml:19
#, no-c-format
msgid "If you want to enable offline raster:"
-msgstr ""
+msgstr "データベース外ラスタを有効にするには次のようにします。"
#. Tag: programlisting
#: administration.xml:20
-#, no-c-format
msgid "POSTGIS_ENABLE_OUTDB_RASTERS=1"
-msgstr ""
+msgstr "POSTGIS_ENABLE_OUTDB_RASTERS=1"
#. Tag: para
#: administration.xml:21
#, no-c-format
msgid "Any other setting or no setting at all will disable out of db rasters."
-msgstr ""
+msgstr "他の値を入れたり、値を入れない場合には、データベース外ラスタは無効になります。"
#. Tag: para
#: administration.xml:22
@@ -77,13 +83,13 @@ msgstr ""
msgid ""
"In order to enable all GDAL drivers available in your GDAL install, set this "
"environment variable as follows"
-msgstr ""
+msgstr "インストールしたGDALのドライバを有効にするには、次の環境変数を設定します。"
#: administration.xml:23
-#, no-c-format
msgid "POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL"
-msgstr ""
+msgstr "POSTGIS_GDAL_ENABLED_DRIVERS=ENABLE_ALL"
#. Tag: para
#: administration.xml:24
@@ -91,19 +97,19 @@ msgstr ""
msgid ""
"If you want to only enable specific drivers, set your environment variable "
"as follows:"
-msgstr ""
+msgstr "一部のドライバのみ有効にしたい場合には、環境変数を次のように設定します。"
#: administration.xml:25
-#, no-c-format
msgid "POSTGIS_GDAL_ENABLED_DRIVERS=\"GTiff PNG JPEG GIF XYZ\""
-msgstr ""
+msgstr "POSTGIS_GDAL_ENABLED_DRIVERS=\"GTiff PNG JPEG GIF XYZ\""
#. Tag: para
#: administration.xml:27
#, no-c-format
msgid "If you are on windows, do not quote the driver list"
-msgstr ""
+msgstr "Windows上の場合は、ドライバリストに引用符をつけないで下さい。"
#. Tag: para
#: administration.xml:29
@@ -115,6 +121,10 @@ msgid ""
"<replaceable>main</replaceable>/environment</filename> where 10 refers to "
"version of PostgreSQL and main refers to the cluster."
msgstr ""
+"環境変数の設定はOSによって異なります。UbuntuまたはDebian上でapt-"
+"postgresqlを経由したPostgreSQLのインストールについては、<filename>/etc/postgresql/<replaceable>"
+"10</replaceable>/<replaceable>main</replaceable>/environment</filename>を編集するの"
+"が好ましい方法です。 ここで、10はPostgreSQLのバージョンを指し、mainはクラスタを指します。"
#. Tag: para
#: administration.xml:32
@@ -127,6 +137,10 @@ msgid ""
"clicking <emphasis>Advanced System Settings ->Advanced->Environment "
"Variables</emphasis> and adding new system variables."
msgstr ""
+"Windowsでサービスとして実行している場合には、システム変数で設定します。Windows "
+"7では、コンピュータを右クリックしてプロパティをクリックするか、エクスプローラの検索バーにコントロール パネル\\すべての<varname>コントロール "
+"パネル項目\\システム</varname>を指定します。 <emphasis>システムの詳細設定 -> 詳細設定 -> 環境変数 "
+"</emphasis>を順にクリックして、新しいシステム環境変数を追加します。"
#. Tag: para
#: administration.xml:34
@@ -134,19 +148,19 @@ msgstr ""
msgid ""
"After you set the environment variables, you'll need to restart your "
"PostgreSQL service for the changes to take effect."
-msgstr ""
+msgstr "環境変数を設定した後は、設定を反映させるために、PostgreSQLサービスの再起動が必要です。"
#. Tag: title
#: administration.xml:39
#, no-c-format
msgid "Creating spatial databases"
-msgstr ""
+msgstr "空間データベースの作成"
#. Tag: title
#: administration.xml:42
#, no-c-format
msgid "Spatially enable database using EXTENSION"
-msgstr ""
+msgstr "エクステンションを使って空間データベースを有効にする"
#. Tag: para
#: administration.xml:44
@@ -156,6 +170,8 @@ msgid ""
"extensions/postgis modules, you can turn a database into a spatial one using "
"the EXTENSION mechanism."
msgstr ""
+"PostgreSQL 9.1以上を使っていて、エクステンションのPostGISモジュールをコンパイル、インストールしている場合には、エクステンションという"
+"メカニズムを使用して、データベースを空間データベースに切り替えることができます。"
#. Tag: para
#: administration.xml:49
@@ -165,23 +181,29 @@ msgid ""
"the functions and comments. Raster and topology are packaged as a separate "
"extension."
msgstr ""
+"中核となるPostGISエクステンションには、ジオメトリ、ジオグラフィ、spatial_ref_sysおよび全ての関数とコメントが含まれています。ラスタと"
+"トポロジは別のエクステンションになっています。"
#. Tag: para
#: administration.xml:55
#, no-c-format
msgid ""
"Run the following SQL snippet in the database you want to enable spatially:"
-msgstr ""
+msgstr "空間データベースにしたいデータベース上で次のSQLを実行します。"
#: administration.xml:57
-#, no-c-format
msgid ""
"CREATE EXTENSION IF NOT EXISTS plpgsql;\n"
" CREATE EXTENSION postgis;\n"
" CREATE EXTENSION postgis_raster; -- OPTIONAL\n"
" CREATE EXTENSION postgis_topology; -- OPTIONAL"
msgstr ""
+"CREATE EXTENSION IF NOT EXISTS plpgsql;\n"
+" CREATE EXTENSION postgis;\n"
+" CREATE EXTENSION postgis_raster; -- OPTIONAL\n"
+" CREATE EXTENSION postgis_topology; -- OPTIONAL"
#. Tag: title
#: administration.xml:63
Summary of changes:
doc/po/ja/administration.xml.po | 74 ++++++++++++++++++++++++++---------------
1 file changed, 48 insertions(+), 26 deletions(-)
hooks/post-receive
