[postgis-tickets] [PostGIS] #5055: XSL headers not being translated
trac at osgeo.org
Mon Jan 17 10:31:20 PST 2022
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: documentation | Version: master
Keywords: |
On the autogenerated file postgis_aggs_mm.xml
The headers are not being translated because they only are defined in the
xsl/postgis_aggs_mm.xml.xsl file.
This makes the translated documents incomplete.
See for example:
https://postgis.net/docs/manual-dev/postgis-
ja.html#PostGIS_Special_Functions_Index
To fix I'm assuming we'd need to:
1. Generate a pot for the xsl file
2. Add to template/xsl/pots
3. Add to build
4. Of course add the component to weblate (since the format is different
we'd need a separate discovery for it, or just import as singleton reusing
the same repo)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5055>
