[postgis-tickets] [PostGIS] #5056: make update-po changes line wrapping for japanese translation
trac at osgeo.org
Tue Jan 18 06:32:37 PST 2022
Reporter: strk | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.3.0
Component: l18n | Version:
Keywords: |
I don't understand why but if I execute `make -C doc/ update-po` I end up
with a single change in file doc/po/ja/reporting.xml.po which consists in
this:
@ -134,8 +134,9 @@ msgid ""
"a four step process on Unix (assuming you already have <ulink
url=\"https://"
"git-scm.com/\">git</ulink> installed):"
msgstr ""
-"変更が大きい場合は、パッチが確実に好まれます。Unix上で次の4ステップの処
理を行います (既に<ulink url=\"https://git-scm."
-"com/\">git</ulink>をインストールしていると仮定します)。"
+"変更が大きい場合は、パッチが確実に好まれます。Unix上で次の4ステップの処
理を行"
+"います (既に<ulink url=\"https://git-scm.com/\">git</ulink>をインストー
ルして"
+"いると仮定します)。"
I cannot read japanese but it looks like being only a matter of where
newlines are added. My version of gettext (0.21) seem to make it so that
80 columns are not exceeded.
The line wrapping was EXACTLY like my `update-po` run would make them
before commit [4c3c8e37839127b67dc3f0cf08f67cddc7441d89/git] which seems
to be coming from weblate.
I suspect weblate install and my system have a different view about when a
line should (or can) be wrapped. Could be locale dependent.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5056>
