[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-291-g54858ec8a
Wed Jan 19 00:46:16 PST 2022
the project "PostGIS".
       via  54858ec8a7a82843c8881192d754fc4d76f7b3d2 (commit)
      from  1cedd55bc98064a467a9c2197f4dc25dee842dc1 (commit)
revisions in full, below.
commit 54858ec8a7a82843c8881192d754fc4d76f7b3d2
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jan 19 08:46:02 2022 +0000
    Translated using Weblate (German)
    Currently translated at 78.0% (228 of 292 strings)
    Translation: postgis/reference_output.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_outputxml/de/
diff --git a/doc/po/de/reference_output.xml.po b/doc/po/de/reference_output.xml.po
index 8fe4a93a6..e3a5f6999 100644
--- a/doc/po/de/reference_output.xml.po
+++ b/doc/po/de/reference_output.xml.po
@@ -7,14 +7,16 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-01-19 03:22+0000\n"
-"PO-Revision-Date: 2021-11-28 22:06+0000\n"
-"Last-Translator: Regina Obe\n"
-"Language-Team: German (http://www.transifex.com/postgis/postgis/language/de/)\n"
+"PO-Revision-Date: 2022-01-19 08:46+0000\n"
+"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
+"Language-Team: German <https://weblate.osgeo.org/projects/postgis/"
+"reference_outputxml/de/>\n"
 "Language: de\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Plural-Forms: nplurals=2; plural=(n != 1);\n"
+"Plural-Forms: nplurals=2; plural=n != 1;\n"
+"X-Generator: Weblate 4.10.1\n"
 #. Tag: para
 #: reference_output.xml:6
@@ -1876,10 +1878,17 @@ msgstr "Die Parameter \"sizes\" und \"bounding_boxes\" bestimmen ob zusätzliche
 #. Tag: para
 #: reference_output.xml:1150
-#, fuzzy, no-c-format
-#| msgid "The array-input form of the function is used to convert a collection of geometries and unique identifiers into a TWKB collection that preserves the identifiers. This is useful for clients that expect to unpack a collection and then access further information about the objects inside. You can create the arrays using the <ulink url=\"http://www.postgresql.org/docs/9.4/static/functions-aggregate.html\">array_agg</ulink> function. The other parameters operate the same as for the simple form of the function."
+#, no-c-format
 msgid "The array-input form of the function is used to convert a collection of geometries and unique identifiers into a TWKB collection that preserves the identifiers. This is useful for clients that expect to unpack a collection and then access further information about the objects inside. You can create the arrays using the <ulink url=\"https://www.postgresql.org/docs/current/functions-aggregate.html\">array_agg</ulink> function. The other parameters operate the same as for the simple form of the function."
-msgstr "Das Feld-Eingabeformat dieser Funktion wird verwendet um eine Sammelgeometriee und eindeutige Identifikatoren in eine TWKB-Collection zu konvertieren, welche die Identifikatoren erhält. Dies ist nützlich für Clients, die davon ausgehen, eine Sammelgeometrie auszupacken, um so auf zusätzliche Information über die internen Objekte zuzugreifen. Sie können das Feld mit der Funktion <ulink url=\"http://www.postgresql.org/docs/9.4/static/functions-aggregate.html\">array_agg</ulink> erstellen. Die anderen Parameter bewirken dasselbe wie bei dem einfachen Format dieser Funktion."
+msgstr ""
+"Das Feld-Eingabeformat dieser Funktion wird verwendet um eine "
+"Sammelgeometriee und eindeutige Identifikatoren in eine TWKB-Collection zu "
+"konvertieren, welche die Identifikatoren erhält. Dies ist nützlich für "
+"Clients, die davon ausgehen, eine Sammelgeometrie auszupacken, um so auf "
+"zusätzliche Information über die internen Objekte zuzugreifen. Sie können "
+"das Feld mit der Funktion <ulink url=\"http://www.postgresql.org/docs/"
+"current/functions-aggregate.html\">array_agg</ulink> erstellen. Die anderen "
+"Parameter bewirken dasselbe wie bei dem einfachen Format dieser Funktion."
 #. Tag: para
 #: reference_output.xml:1152
Summary of changes:
 doc/po/de/reference_output.xml.po | 23 ++++++++++++++++-------
 1 file changed, 16 insertions(+), 7 deletions(-)
hooks/post-receive
