[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0-301-g5fcc13dde
git at osgeo.org
git at osgeo.org
Wed Jan 19 02:25:03 PST 2022
the project "PostGIS".
via 5fcc13dde2189d3d671da2ee5668bffcd4066486 (commit)
from 10f47386618248da1d1bc42343092880a12dad2a (commit)
revisions in full, below.
commit 5fcc13dde2189d3d671da2ee5668bffcd4066486
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Jan 19 10:24:50 2022 +0000
Translated using Weblate (Japanese)
Currently translated at 99.6% (291 of 292 strings)
Translation: postgis/reference_output.xml
Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_outputxml/ja/
diff --git a/doc/po/ja/reference_output.xml.po b/doc/po/ja/reference_output.xml.po
index 073ce482b..327f79d1e 100644
--- a/doc/po/ja/reference_output.xml.po
+++ b/doc/po/ja/reference_output.xml.po
@@ -6,15 +6,16 @@ msgstr ""
"Project-Id-Version: PostGIS\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2022-01-19 03:22+0000\n"
-"PO-Revision-Date: 2022-01-11 01:17+0000\n"
-"Last-Translator: TERAMOTO Ikuhiro <yellow at affrc.go.jp>\n"
-"Language-Team: Japanese (http://www.transifex.com/postgis/postgis/language/"
-"ja/)\n"
+"PO-Revision-Date: 2022-01-19 10:25+0000\n"
+"Last-Translator: Sandro Santilli <strk at kbt.io>\n"
+"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/"
+"reference_outputxml/ja/>\n"
"Language: ja\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
"Plural-Forms: nplurals=1; plural=0;\n"
+"X-Generator: Weblate 4.10.1\n"
#. Tag: para
#: reference_output.xml:6
@@ -2897,7 +2898,7 @@ msgstr ""
#. Tag: para
#: reference_output.xml:1150
-#, fuzzy, no-c-format
+#, no-c-format
msgid ""
"The array-input form of the function is used to convert a collection of "
"geometries and unique identifiers into a TWKB collection that preserves the "
@@ -2907,12 +2908,10 @@ msgid ""
"functions-aggregate.html\">array_agg</ulink> function. The other parameters "
"operate the same as for the simple form of the function."
msgstr ""
-"配列入力の形式は、ジオメトリのコレクションを変換して、一意の識別子をTWKBコレ"
-"クションに持たせるためのものです。これは、コレクションを展開して、オブジェク"
-"ト内部に関する情報にさらにアクセスするのに使えます。<ulink url=\"http://www."
-"postgresql.org/docs/9.4/static/functions-aggregate.html\">array_agg</ulink>関"
-"数を使用して配列を生成できます。他のパラメータは、単純な形式のものと同じで"
-"す。"
+"配列入力の形式は、ジオメトリのコレクションを変換して、一意の識別子をTWKBコレクションに持たせるためのものです。これは、コレクションを展開して、オブジェ"
+"クト内部に関する情報にさらにアクセスするのに使えます。<ulink url=\"http://www.postgresql.org/docs/"
+"current/functions-aggregate.html\""
+">array_agg</ulink>関数を使用して配列を生成できます。他のパラメータは、単純な形式のものと同じです。"
#. Tag: para
#: reference_output.xml:1152
Summary of changes:
doc/po/ja/reference_output.xml.po | 21 ++++++++++-----------
1 file changed, 10 insertions(+), 11 deletions(-)
hooks/post-receive
